-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   Engine code 46???? Pulsing Lights??? (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/engine-code-46-pulsing-lights-174089/)
MikeThomas Oct 18, 2007 12:40 AM
So could the check engine code 46 (charging voltage too high) be the source of my dreaded pulsing lights? I hear the pulsing light can be a diode in the alternator....can that be the cause of my "overcharging".
MikeThomas Oct 18, 2007 01:23 PM
Ahem.......?
whereswaldo250 Oct 18, 2007 02:05 PM
Hey Mike I wish I could help you:( I would also like to know[redface]
wannadiesel Oct 18, 2007 06:55 PM
I would throw an alternator at it.
TJE Oct 18, 2007 09:46 PM
I had the same problem on my 91.5, for about three years to be exact. I had the alt. tested, it was good. I changed the VR, and still I had pulsating head lights. I even ran a ground from the alt. to the frame, and still the head lights had a pulse to them. I finally took it to an electrical shop. in about ten minutes he found the problem. A bad ground, the battery was not getting a good ground. I had even replaced both terminals, with gold plated terminals.
I hope this info might help you. Tony
