Engine block, repair or replace?
I recently bought an engine, with "110,000" on it. I have found something I'm not entirely comfortable with. On the #6 main, where the piston squirter is, the block is cracked right there. It starts and ends at the hole where the squirter is. It really can't go any farther but a crack is a crack, right? Also this engine is going to need to be sleeved on #5 as water got in the cylinder and caused some damage. Should I just look for another block and put all the guts from this engine in it? I know a picture would help but I don't have a digital. I thought I got a good deal up till now.[dummy]
That sucks. I've seen a good deal of these early motors going on ebay for pretty cheap. I'd guess it'd be easier to start with a good, clean block. Even if a machine shop can fix it up, it may cost more (not to mention there is no price to having peace of mind)!
Well, depending on the depth and size of the crack, it can be welded. Ive never been inside of one of these motors so I cant offer too much input on weather or not it is a BIG deal or one that can be repaired and life moves on. But I would take the block to a reputable engine rebuilder/machinist and ask them for their opinion. Thats usually the best way to go.
I know its a pain in the butt, but I would go with a new block and not ever have to worry about it any more.
that sounds like my old motor.[director]
if itsss a 98 thru 2001111, look for 53 cast intao side of block and do google on blasokc stitch for 53 cummianss,,,,, buck neverr used it on diesel and cant sayy aboutt its effficeancy but we haeee used stitchaing on industrail castiangs and staem enginesss buck
Originally Posted by buckwill
(Post 1234856)
[laugh] |
iii haddd arrestttt and straoike sixxxx yearss ago,,,,, andd trraemorr froam the storake,,thiss is whatt ivee got,,,, doesntt get ansy betterr,,, if i couldddd woudl have doen better six yearss ago,i shsould have knowb betterrr tahn to come heree anways,,,,,,
block
dont go away Buckwill. there are spelling "nazis" on every board. if one cant read or understand what you typed they need to go back to school or just stay away themselves.[coffee]
It's not the 53 block. It is a 91.5 model engine. I will take it to the machine shop and see if he can save it. Otherwise, I will be looking for a donor block. I only gave $750 for everything so if the IP is good and the head is useable I didn't get ripped too bad.
Originally Posted by jughead
(Post 1235091)
Dan |
I have seen block's crack there before. Where the oil piston cooling nozzel is? I have would have it welded it's no big thing. As for sleeving, I would bore the hole unless, it has pin holes. #6 hole is bad about pin holes, Bore no more than 40 over. Sleeves are the best fix they do cost a bit more.
Buckwill, I'm sure had he known, he'd have held back better. You won't find too many hard feelings here, stick around.
Originally Posted by Redleg
(Post 1235551)
Hey Peyton, keep us informed on what ya decide, im sure someone round here wouldnt mind taking it off yer hands (after all ohio isnt too far from me [whistle] ) lol
| All times are GMT -5. The time now is 07:43 AM. |
