Electrical Pulse
Electrical Pulse
My truck's electrical system has a pulse. It is very noticeable at an idle and goes away at about 1500 rpm. The lights pulse as wellas the voltmeter in the cab. The 97 cummins I had did it a little but this is crazy. Do I need a new or bigger alternator? Thanks.
mine did that real bad finally overcharged so bad my battery fried in tucumcari n.m went to johns diesel repair steve a great mec. rewired the sys. relay from alt. to batt. i am no wiring guru but what he did cured my problem. new alt. and batt. it sits where it is supposed to. these people are a
real credit to the repair ind. he called to make sure all was ok going home
Mine does the same when I intially start it in the morning, the voltmeter pulsing that is. It did it real bad with this crappy dry cell battery I got with the truck. I've since changed out the battery. I think it's just the heater grid pulling power. The ground on the core support is fine for me, I ain't worried about it though, he still starts up like a champ
Well, I checked the core support ground. I moved it to a new spot and cleaned it up real good. No dice- still doing the same thing. I think the alt is just ready to be replaced. She charges fine though. I don't know. Guess I'll leave it for now.
I couldn't figure mine out, so I took it to a shop. They ran a small ground from the batt. to the body...fixed the problem. I no longer have a problem with my lights pulsating. The alt. gauge....it still pulsates.
Good luck, Tony
Good luck, Tony
Thanks Tony. My biggest issue is my "strobe lights" at night so maybe I can figure it out from there.
Next steps: If the regulator is not an OEM Mopar unit, hit the junkyard and find a couple that are (all Mopars from about '72 until the late '80's used the same one) and try them out.
Run a ground from the engine to one of the screws holding the regulator to the firewall.
. I cleaned up the existing grounds and added more/bigger ones with no luck. That was years ago. So far no problems except that sometimes folks think I'm flashing them
.Back when I was trying to fix the problem someone mentioned that one of the diodes in the alt may be bad. I never got around to checking that. It charges fine. I don't have the external regulator though.
