Electrical problems with the dash lights?
Old Apr 6, 2009 | 09:06 PM
JDP's Avatar
JDP
under the dash there is a big white plug or harness that is not connected to anything and i found that one of the prongs was a key on power wire that i cut the wire to and ran for my key on power wire for my cd player and now cd player works but not my dash lights. When i pull the *** for the headlights they come on but not my dash lights. I tried puttin the wire back into the plastic type plug and they still dont come on. If any body could help it would be really apprec.
Old Apr 6, 2009 | 09:23 PM
Thunderhog's Avatar
Did you check the fuse for the dash lamps?
Old Apr 6, 2009 | 10:48 PM
JDP's Avatar
JDP
i checked the fuse that said guages and it was fine. I didnt check the lamp fuse. The wire is a thin blue with a white tracer.
Old Apr 7, 2009 | 10:55 PM
gear jammer 91"'s Avatar
Was it a round plastic plug? If it was, it should probably be plugged into the back of your gauge cluster.
Old Apr 8, 2009 | 03:58 PM
schamran's Avatar
Do your marker lights work? Start there. I believe the dash lights and marker lights are on the same fuse.
Old Apr 8, 2009 | 04:21 PM
Thunderhog's Avatar
I know in the "good ol' days" the dash and tail lamps were connected. I dont have a wiring diagram for that rig, but I know Chrysler used Orange for dash lamp wiring for a long time. You really need a wiring diagram to diagnose properly. Otherwise, start where you have power (the switch, etc.) and work your way to the problem.
Old Apr 8, 2009 | 09:43 PM
JDP's Avatar
JDP
Yeah the marker lights arent workin either i still havent checked the fuse for the dash lamps and i did notice where the radio is there is a harness with a orange wire that i did plug into when i was hooking up the radio and then unplugged, maybe i blew the fuse who knows gonna look at it this weekend, Keep comin with the info this is killin me.
Beefdoc
Jun 15, 2012 09:54 AM
NoSparkplugs
17
May 17, 2009 10:36 PM
larry30000
Feb 26, 2006 06:29 PM
eric13
Oct 17, 2005 07:05 PM
CHarlan
Aug 6, 2003 08:40 PM
