Electrical Problem
Electrical Problem
Last night driving home my lights and guages were fluttering a little and this morning going to work all my lights, guages, windows, overdrive, everything electrical except the starter and evidently the fuel solenoid stopped working. Where is a good place to start looking for this problem?
No change in the battery, it starts the engine easily. Occasionally the guages come on and overdrive kicks in but doesn't stay on long. Acts like a loose connection in an area that affects the whole system.
Were the headlights randomly flickering with the road vibrations or flickering like an arcing connection?
I would start with the fuse links.
A connection that would cause flickering would also be producing some heat.
If you know how I would also be checking voltage drop between battery cables, battery/ alternator and fuse links.
Jim
Jim
Closely inspect the harness near the CPS. If it is frayed, replace the CPS.
What's happening is that both functions are controlled by the PCM, which withholds said control till it knows the engine is running. (CPS)
hope it helps
