Electric Fan Mount
You might consider designing some flaps to put in the spaces above & below the respective fans so that the air wont go around in circles while at a stop. The only ones I can think of were on 1979 VW Rabbits. When at speed they open to let good air flow.
Never been a fan of those either. I guess in a pinch and a temporary situation they'd do but I'd rather have a more permanent, clean/professional looking install.
Some time ago I tilted my radiator straight up and started running electric fans. I have always had to be careful about money, so haven't been able to plunk down mega bucks for a custom dual fan shrouded solution. I first went with a Taurus fan but the motor would hit the fan hub under abuse which ruined the radiator. Then I tried the round zip ties and those chainsawed my radiator. That's why I built a frame that the fans are attached to and only tough the radiator with 1/2" foam weatherstripping.
If I want them out of the way I just unplug the power connectors, remove two bolts and they are out.
Works great except idling in town about 90 deg. The engine stays cool enough but the A/C over pressurizes. I might stick a pusher in front of the condenser if I can do it without ruining the stock look of the grill.
That is basically the same set-up I did....to run two 12" fans and use the factory mounts. The fans seem to be OK in cooler weather...but get close to 30*C and those little fans barely keep the temps under control at idle, and that is with no AC running.
Mine never seems to overheat. I don't even use the fans at all in the winter and spring until I need the intercooler or A/C. It will run hot when pulling a heavy in the heat of the summer.
Why are you guys removing the stock fans? They work great.
I had to find a new cooling fan for my hot rod years ago. Here's a video of what I installed.
Mercedes cooling fan.avi - YouTube
Diesel Girl
18
10-06-2013 03:03 PM
92smokin blacky
10-07-2011 03:08 PM
cj5er
12-20-2009 09:19 PM
WACTD
31
04-14-2007 10:55 AM
