elbow in intake side of turbo
Old Nov 29, 2004 | 09:07 PM
andyr354's Avatar
Found out while putting new boost boots on that the thing is cracked. The ring around the top is almost all the way broken off.
It is the 90 degree elbow that connects to the turbo with a clamp and o-ring, then the intercoler duct attaches to the other side.
I can't quite make out the part# on it due to the roughness of the casting. Trying to get one from cummins if possible.
Anybody know the name, part#, or something about where to get one? Anybody got a good one laying around?
Old Nov 29, 2004 | 09:46 PM
CrewCabCummins's Avatar
I would think that you could have it welded up...if you can't find one. Did it crack from being "over tightened"?..
Old Nov 29, 2004 | 10:06 PM
Smkndzl's Avatar
Andy , I got a brand new one sitting here that I almost threw away today , if you want it , maybe you can make arrangement to get it shipped to you. PM me
Old Nov 29, 2004 | 10:09 PM
andyr354's Avatar
Somebody tried to JB-weld it already once and that has broken loose. I don't know what caused it to break, was that way when I took it appart. Always something huh. ...
It is in a pretty hard to fix area, but who knows. I don't know where I could get it welded around here if it is aluminum Need to stick a magnet on it and see if it is aluminum or cast, but seems aluminum.
It is in a tough area to work with. Has the o-ring grove on one side and the clamp goes around the outside.
Cummins parts guy called back and he doesn't think it is a cummins part, dodge is no help of course
Need to get this fixed soon.
Old Nov 29, 2004 | 10:12 PM
andyr354's Avatar
That would be outstanding!
PM sent.
Old Nov 30, 2004 | 01:13 PM
andyr354's Avatar
Finally got a good part number and ordered one. For anybody else searching
air pipe# 3918800
o-ring 3919852
clamp 3069053
My part number was very hard to read and not cast very well. So it took quite a bit of trying and research to finnaly find it.
Old Nov 30, 2004 | 09:19 PM
Smkndzl's Avatar
Andy , the one I have is a 90 bend with a 3 in CAC hose , part# 39186885 , it wont work with what you have , your part will be a 87 degree bend with a 2.5 CAC hose .
Old Dec 14, 2004 | 05:18 PM
andyr354's Avatar
The saga continues.
Reliablegoods showed 2 on their website, but they emailed me back saying that they were out of stock.
Bought one from somebody, wrong one and sent back
called up cummins, said it is a good number. Still trying to track one down saying they haven't found one in stock any where yet.
I rigged up a simple boost guage and took it for a drive. Must not be leaking terribly bad, I was able to get arond 18psi out of it with my foot on the floor at 80. Or is that low?
The local hardware store had a nice 0-30psi guage, couple of brass hose barbs and clamps, and a lenght of vaccum hose. Just ran it out from under the hood and in the window for a test drive.
Old Dec 15, 2004 | 05:40 PM
That sounds good for a stock truck.
Taquache
21
Jun 24, 2012 03:11 PM
Billut
Oct 18, 2009 01:57 PM
Alan_Reagan
Jul 26, 2009 01:13 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
cquestad
258
Jan 22, 2006 09:58 AM
