View Poll Results: EGT's . . . . Where do you let off?
1250*F
19.61%
1300*F
21.57%
1400*F
13.73%
1500*F
13
25.49%
What's an EGT?
7.84%
Apple juice
11.76%
Voters: 51. You may not vote on this poll
EGT's. Where do you draw the line?
Old Oct 25, 2006 | 10:05 PM
BC847's Avatar
1st Generation Admin
Mark your ballot (above) as to where you pucker-up?
As far as this poll goes, I would think a regular work-truck (constant heavy pulling) might not apply.
Naturally, 1250*F is for a 100% duty cycle (WOT all day long).
I pretty much use my heap as a play toy. WOT 0mph to the posted speed limit ( ) blasts here and there. Otherwise Sunday driving.
More fuel is more power. I don't want to toast my mess, but I do want to run it for all it's worth.
What say you?
Thanks,
David
Old Oct 25, 2006 | 10:17 PM
flashgordon's Avatar
But pucker, is 1300*
but that's for pulling if i was to play and had it in the high temp momentarily, like a drag race............maybe 1400
W900A's Avatar
For a play toy I'm not concerned about seeing 1300-1800*F. Long ago I had one of the first PowerStrokes, 94, and would bury the pryo at 1800*F when I was tugging on a sled. Truck had 152K when I sold it and ran fine.
The B listed in my sig I ran to 1200-1350*F continuous in the work truck it was in before I pulled it for my project truck. What EGT an engine will withstand depends on many variables, but air flow (not necessarily boost PSI) has a lot to do with it. If you stay around 1400* or so it'll live a long and happy life, especially as a toy and not a tugger, my .02
Old Oct 25, 2006 | 11:34 PM
farmer0_1's Avatar
i only use my pu to pull loads on the farm. 5-6 ton loads of hay over mt.hood. i want to make it last so if i am on a 20 min hill i keep it under 1250. may have to shift down alot easier than a repair. so far haven't turned a wrench on her under the hood execpt filters. coarse it has not broken 90k on the pu yet.
Old Oct 26, 2006 | 02:37 AM
timb's Avatar
I take the old girl to the 1600 peg on the guage quite often when I am drag racing. but it does'nt stay there long at all. I can take her up to 1400 just passing another rig. I just try not to let it stay long at those temps.
Old Oct 26, 2006 | 06:23 AM
JD730's Avatar
When towing I won't let the Egt's exceed 1000 to 1100 for any length of time, pryometer accuracy is a big concern. I need to install a 2nd one to confirm.
When I'm drag racing I won't even flinch, might not even notice where the pryo is at.
Old Oct 26, 2006 | 03:41 PM
dpuckett's Avatar
I've hit 1400 pulling a small trailer with another 1st Gen up a hill, but it was near the top, and I know Banks (they arent known for pushing the envelope) says 1300 all day long is ok, so 1400 for 40sec shouldnt hurt. I normally dont hit 1250 running empty.
Daniel
Old Oct 26, 2006 | 04:12 PM
Is the last "r" in "Pyrometer" too high?
I don't even look at it unless I'm running hard up a long hill. I really don't wanna know...
Old Oct 26, 2006 | 06:07 PM
gman07's Avatar
Before the Stage IV i could get 1400*; I didn't really mind doing that as long as it was for a short time. I get nervous even at 1250* on long pulls because of advanced timing.
Old Oct 27, 2006 | 03:44 AM
timb's Avatar
I took my wife down the drag strip last spring and after the run she asked me if I even look at the piro. I told her that I know for a fact that it will only go to 1600 because there is a peg there to stop the needle. She gave me a real strange look.
77machomopar
Oct 7, 2009 02:50 PM
Treangen
Apr 4, 2007 08:27 PM
dsl kicks gas
Dec 28, 2006 08:18 PM
JyRO
Jan 20, 2006 09:28 AM
