EGT temp question
Old Jul 24, 2010 | 05:52 PM
Onemoparnut's Avatar
EGT temp question
I had the truck running at an idle and I took a temp gun to the exhaust ports on the head.
#1 230
#2 280
#3 280
#4 280
#5 280
#6 260
Does that sound about right I had just come off about a 10 mile ride. I pulled in the drive and opened the hood and checked them. How much fluctuation in temp is too much.
Old Jul 24, 2010 | 07:07 PM
#1 is a little low, but there's better cooling at the front of the head. How's it idle? If it's running smooth I wouldn't worry.
Old Jul 24, 2010 | 07:45 PM
It seems to run smooth but right off idle as you step on the throttle there is a little miss I think. Brandon heard it before he said it sounds like a helicopter that is the best way I can describe it.
Old Jul 24, 2010 | 08:46 PM
yea it always sounds choppy like a helicopter. i figured it was the square tubed stacks though
maybe a compression test on cylinder 1 ?
Old Jul 24, 2010 | 08:51 PM
Yea if I had a diesel compression tester. I am wondering if it is a bad injector in number 1 and maybe number 6 also.
Old Jul 24, 2010 | 10:02 PM
rattlerbob5.9's Avatar
Swap 1+ 2 injectors and see if anything changes. Simple cheap and easy.
Old Jul 24, 2010 | 10:07 PM
Thats a good idea
BBTexas
Nov 23, 2010 02:09 PM
st.rodder2
16
Jul 18, 2010 11:24 AM
duallydave
Aug 27, 2008 09:49 PM
offroadcpa
Mar 14, 2008 08:12 PM
jmccart
14
Nov 20, 2006 06:45 PM
