EDM's in!
Old Sep 4, 2006 | 07:24 PM
  #31
Pics of the valet setup:
With the ground AFC lever, the valet switch was not real effective at controlling low boost smoke. Now that I'm running an unground AFC lever, it's a more effective control. It will not exceed 1250 on straight diesel with the AFC fuel shut off. I could actually lend the truck to somebody without worrying that they'd melt the pistons, all I'd have to do is pull the fuse.
Old Sep 4, 2006 | 08:26 PM
  #32
92DIESEL's Avatar
Congrats on the EDM's- Can't wait till Oct to get that ride
Michael
Old Sep 4, 2006 | 09:21 PM
  #33
loch's Avatar
Cool I love mine, I wouldnt go to a POD now if they paid me.
Old Sep 5, 2006 | 01:52 PM
  #34
Just an update, I drove it some more this morning. Unfortunately the rain is back so I couldn't play.
EGT at idle is lower and falls faster. I was in traffic with the defroster going, with the POD's EGT would stay at 350 with the A/C compressor running. While sitting at a traffic light the EGT will drop below 300 under the same conditions now.
This makes me think my fuel economy is going to improve.
The next thing I want to try is turning the AFC cone to see if I can tune all the zero boost smoke out. I've been driving around like there's an egg between my foot and the accelerator for a year and a half and I'm getting tired of it. Now that I have more fuel than I can possibly use I want to try to clean up the low end some more.
Old Sep 15, 2006 | 07:54 PM
  #35
Dredging this one up from the depths for an update.
Even with the stock AFC lever, the cone set on the shallow side, and the nut on top of the cone ground to get the fuel pin all the way down at the bottom, there is still a good puff of smoke on a normal upshift. I will have to turn the pump down some if I want to eliminate that completely. I may do that after I dyno the truck.
"City" fuel economy results are in. No change, still mid 14's. I'm not surprised, the holes in these things looked to be every bit as big as the holes in the POD's - and these have two more holes!
Old Sep 16, 2006 | 12:17 AM
  #36
flashgordon's Avatar
So you have been able to reduce you smoke while retaining your power w/the new EDM over the POD'S?
Old Sep 16, 2006 | 07:48 AM
  #37
Not quite. Less smoke, MORE power!
Old Sep 16, 2006 | 08:58 AM
  #38
So when's you next dyno days
I'm getting excited for you
Old Sep 16, 2006 | 09:30 AM
  #39
I might be running it next weekend. If not then, the end of October out at Fall Brawl.
Old Sep 19, 2006 | 12:33 AM
  #40
swank's Avatar
i'm tellin ya dave, more timing. i really am amazed with what happened when i played with the pump a little. might be time to skip a tooth, eh?
Old Sep 19, 2006 | 04:29 PM
  #41
I'm thinking I might need less timing. I can't get rid of the black smoke on shift recovery. I'll leave it be until I dyno it, then mess with it some more.
Old Sep 19, 2006 | 08:01 PM
  #42
DLittle's Avatar
Wanna What size are the holes in your EDM's ?
Old Sep 20, 2006 | 06:46 PM
  #43
Big. Sorry, I don't know, I didn't ask. By eyeball I'd say they are easily as big as the holes in the POD injectors. Not hard to see with the naked eye.
Old Sep 20, 2006 | 09:05 PM
  #44
mhuppertz's Avatar
My truck never got more than 18.5 mpg from the time I got it. Not everybody gets 20 mpg, and there doesn't seem to be any good explanation why.
Maybe it's because you are dragging around six tires!
I'm over 20 on the highway at 65, best of 24mpg.
Dave, have they given you a guess on the price of a new set of these?
Old Sep 21, 2006 | 03:37 PM
  #45
They should retail for a heart stopping $1k.
