Dumb Question about Block Heater
Old Feb 19, 2007 | 10:29 AM
justagoodolboy's Avatar
Ok folks, don't kill me over this, but after searching the forum I have determined that the block heater was a standard option on all diesels. Problem is, I cannot locate anything that remotely resembles a block heater, or even plug or torn-away wire for that matter. Can someone please tell me where this is physically located on the engine, and if my research was in vain and there could have been some diesels without this option?
Thanks!
Old Feb 19, 2007 | 11:10 AM
gcliburn's Avatar
mine is on the right side of the engine. it is in a freeze plug, I think it may be in the 2nd one.
Old Feb 19, 2007 | 11:11 AM
Redleg's Avatar
Look at the side of the block under the oil filter. It would have mounted right into the water jacket through a freeze hole. You may just need to attach a new cord, otherwise by one after market and remove the freezeplug and add it on.
Old Feb 19, 2007 | 02:32 PM
gomerpile's Avatar
also if you have your manual, it has a pic of where it is
Old Feb 19, 2007 | 10:35 PM
DBF's Avatar
DBF
On the passenger side near the jack-handle storage, I have a cable with a cover over the end. If you find that and remove the cover, you'll find the plug for the block heater. Follow the cable to the actual heater.
Regards, DBF
rjm022
Dec 11, 2019 09:17 PM
SpeedyWS6
15
Feb 2, 2011 07:22 PM
supersonictoys
Nov 8, 2008 09:17 PM
modiesel
Mar 7, 2008 10:44 AM
Reelay
Dec 1, 2005 06:14 PM
