Drum brakes to caliper brakes.
Old 04-15-2019, 06:57 PM
fremec's Avatar
I want to swap my rear drum brakes to caliper,what year of dodge rear diffs can I use for an easy swap on a 92 D250?
Old 04-16-2019, 12:08 AM
Received 1,331 Likes on 862 Posts
Other then going with a rear disc conversion system, the other rear diffs out there will most likely cause your truck to have a wider track width. Most of the newer disc rear axles from...Dodge, Chevy, Ford etc are all wider then our old 1st gen's.
Old 04-16-2019, 05:32 AM
Angry Johnny's Avatar
There isn't any really easy swap. Here is my rear disc conversion thread.
Disc conversion
Since this was done I have added an adjustable proportioning valve and an inline ball valve to keep pressure applied to the rear calipers for a parking brake. Mounted both of them in the floor of the cab outboard of the drivers seat. I'll have to try and get some pics. I've also done a hydroboost conversion which I absolutely love.
Old 04-16-2019, 02:55 PM
I agree....going Hydro boost is a better choice then converting to rear discs.
Old 04-16-2019, 04:59 PM
But I did both.
The following 2 users liked this post by Angry Johnny:
1992 Renegade (04-16-2019), NJTman (04-17-2019)
Old 04-18-2019, 11:59 AM
cabtruck's Avatar
The rearend in a first gen is narrower than the front a rear axle from a 05. 06 Chevy is the same with as a dana 60 dodge front and has factory disk brakes if you’re really wanting to upgrade you can buy a bolt on bracket for the front for 2 piston caliper and 14” rotors
Old 04-19-2019, 03:16 PM
u2slow's Avatar
A complete 01-02 Dana 70 with rear disc may be the easiest. Perches are the same spacing. Same yoke. Same pinion length. Same tube diameter. Even has the ABS sensor. Its about 6" wider overall though (65" vs 71") which you can balance out with spacers (front), and/or different wheels, or just not care (how I roll currently).
You can't just swap the brake hardware from the newer diff. The flanges on the axle tube are much beefier, and a different pattern/spacing. Some people have copied these disc flanges in order to do such a transplant.
fordmann.com | F-350: Sterling Rear Disc Conversion
"https://www.pirate4x4.com/forum/international-harvester/483369-1-ton-fat-***.html"
note: replace *** with a, s, and s
Old 04-21-2019, 08:14 PM
fremec's Avatar
Thanks to all you guys for your info
Geico266
11-23-2005 04:20 PM
AggiePhil
11-09-2005 03:41 PM
BIGHEAD
09-20-2005 08:54 PM
rockjeep73
13
11-13-2004 01:13 PM
OH Sick
12-13-2002 04:45 PM
Quick Reply: Drum brakes to caliper brakes.
