Drop spindles for a 92
Old Mar 2, 2008 | 10:57 PM
Santaclaus's Avatar
Has anyone found a souse for drop spindles for a 92 D250? I would like to replace the front springs but like the low front end. I plan on lowering the rear also.
Mike
Old Nov 16, 2009 | 10:30 AM
rcts's Avatar
Mike any luck on the spindles? Lowering question?
I noticed this post where the guy turned the front rear leaf spring mounts upside down.
https://www.dieseltruckresource.com/...=D250+lowering
Is this what you did as well. On the year I would use a longer shacke rather than cut the mount off and make it higher as this guy did. Don't think he needed to cut the rear mount up.
Thanks for your time.
Reg
Old Nov 16, 2009 | 04:54 PM
Santaclaus's Avatar
Might work for 4 wheel drive, I'm 2 wheel. ( Coil springs)
Mike
Old Nov 16, 2009 | 09:17 PM
Riflemanusmc's Avatar
Registered user
Mid America Customs has 2 inch drop springs and lower control arms....
Old Nov 16, 2009 | 10:10 PM
rcts's Avatar
sorry it was not for a 4x4, I was saying the rear spring hangers turned upsidedown!
Sorry guys, I'm a 2wd D250, i was talking about the rear leaf spring, front hanger!
Reg
Old Nov 16, 2009 | 11:06 PM
Bogie's Avatar
Here is a good thread on lowering trucks on Ramcharger Central
Old Nov 17, 2009 | 04:50 PM
93Fury's Avatar
$600 for lower control arms? I'm in the wrong business!
Old Nov 17, 2009 | 05:30 PM
Registered user
Yea...Thats what I thought too..
Old Nov 17, 2009 | 09:32 PM
93Fury's Avatar
So nobody manufactures drop spindles for the old Dodges? When I find the right 3rd gen, the dually is getting a resto probably with air ride. I am NOT paying that much money for control arms, I'll fabricate them and probably half the air system for $600. I am still shocked by the price.
Old Nov 18, 2009 | 06:16 AM
Those are for 1/2 ton anyways.
Old Nov 18, 2009 | 06:21 AM
93Fury's Avatar
Yeah but if you swap the bushing it's the same control arm.
Old Nov 18, 2009 | 05:29 PM
sdstriper's Avatar
The uppers are the same. The lower control arms are diesel specific...and the later 1st Gens are better than the earlier ones. 92-93' are the better ones IIRC.
Old Nov 18, 2009 | 05:46 PM
jimbo486's Avatar
interesting. thicker casting, boxed or what? could later control arms be swapped into an '89-'91?
Old Nov 19, 2009 | 06:32 AM
93Fury's Avatar
Yes they can. I swapped diesel to gasser, gasser to diesel blah blah blah. What is different in the gasser is the lower control arm bushing and the hole in the frame are smaller and use a smaller bolt.
Old Nov 20, 2009 | 08:35 PM
Registered user
6 bills is still alittle thick man....
mrmoopoo
Jul 7, 2008 08:39 PM
smokeyram
Apr 14, 2007 04:38 PM
csramsey640
May 16, 2006 10:49 AM
gunracer1
Dec 20, 2005 10:16 AM
