Driver side window fell out
Well, fell down really,
This morning my window glass separated from the narrow metal channel at the top of the window regulator that holds the glass in place when I tried to run it down so I could spit Copenhagen on the Prius behind me (got 'em in case you're wondering). The glass fell down into the door pretty hard but didn't break. Cold ride in to work (31*F). Pleasant ride home (59*F).
I pulled the plastic stuff off of the door when I got home and reset the glass onto the regulator. I ran it up and down a couple of times and it promptly fell off again.
It looks like there use to be some thick double sided tape or weatherstripping between the glass and the metal channel to keep them married.
Any of y'all have experience with this or have any advice for what I should use to connect the glass to the regulator?
-Niemand
-Niemand
Received 1,637 Likes
-Niemand
-Niemand
I used a bead of adhesive sealant in the channel, set the glass in the channel, let it cure, then put the assembly back into the door. No problems since.
I used a clear sealant, such as this:
or this too. I buy this stuff by the case, and use it on almost every job I do.
N. Besonderes (12-11-2018)
Thanks.
I think that's going to work out better for me than trying to re-tape it since that channel is so tight to start with.
-Niemand
-Niemand
I forget what that stuff is called. We used to have a roll of it at the dealership years ago. We would soak it gasoline and then press the window into it. It was a PITA and super messy. If you can use something else I would certainly try it. I hated doing that job.
Hey Johnny, was it butyl "putty" tape, or does that not ring a bell?
FWIW I think GEOFlex is pretty comparable to what T recommended, if that happens to be readily available. I have also had good luck with Lexel in similar applications.
I think it is called Butyl tape and you should have a glass shop install the window properly. I have had bad luck with trying to do it myself over the years....if the adhesive is to tough and the window is not lined up properly it will put stress on it and it can shatter for no reason....yup been there. Also if the adhesive is too weak the glass will eventually pull clear of the channel again and could drop into the door and break....been there as well. After sucking it up and having a glass shop install it properly I have never had an issue since.
Honestly it's been so long since I've had to use it I don't remember. Newer vehicles don't use it any more.
Maybe I can hack it myself for now, just to get it operational again, and then take it to a shop later when I can leave it with them. It's my only means of conveyance right now.
I would kind of like to clean up the metal parts of the regulators and paint them first though.
I'll have to think about this.
Thanks for all the helpful advice,
-Niemand
I did that window (driver side) about 6 years ago. So far,so good.
Any glass shop should have that strip stuff AJ is talking about. It's a butyl sealant
Pipes
58
03-13-2012 09:44 AM
