Driver side drop
Old Jul 20, 2013 | 12:49 PM
Greed 93's Avatar
Driver side drop
I'am converting my D series to a W, and found a great deal on a Dana 60 kinng pin driver side drop. Wondering if anyone has swapped one of these before and if there where any issues ?
Old Jul 20, 2013 | 03:14 PM
93-12Smoke's Avatar
Well ya need a ds xfer case. Think that 60 would also need to be reverse rotation
Old Jul 20, 2013 | 03:36 PM
flyboy129's Avatar
If it is a high pinion 60, it will be the reverse cut gear. There were a few early ford 60s that were low pinion, iirc. What did the 60 come from? 94-02 Dodges and 92-? Fords were the ball joint knuckle variety. Dodges also were the crappy vacuum disconnect system and unit bearings. I believe Fords went to unit bearings in 97ish? I am putting a 78 HP 60 from a Ford truck under my conversion. I will use the divorced-driver's side drop 205 from the same era. All I need to find now is the 2wd 5 speed to put between it and the engine. You will also need a way to mount the t case shifters on the driver's side of the transmission or fab some brackets to do so.
Old Jul 20, 2013 | 03:58 PM
I sincerely hope that you're going to share that with us with some nice pictures and associated notations of what and how...
If so..... I'd like it done by X-mas so I have something to read in between New Years...
Thanks !
Old Jul 20, 2013 | 10:40 PM
Greed 93's Avatar
Thanks !
Copy that ! It is a hp from a ford already converted to manual hubs, just picked it up tonight. Heading in to pick and pull in the am for a transfer case from a 03 dodge 3500, then going to refurbish the axle then its go time ! Hoping to have it done by end of October. I will indeed take pictures and notes.
Ron R
Sep 16, 2008 11:09 AM
guyssets
Sep 24, 2005 02:13 PM
Gordonville
Aug 13, 2004 11:07 AM
popeye
13
Jan 13, 2004 11:54 AM
atc250r
Aug 26, 2003 08:52 PM
