Driveability
Old Mar 11, 2011 | 09:49 PM
blue92's Avatar
Driveability
I recently swapped out my 190's for swome POD's. Thetruck certainly runs better, but I'm having some driveabiloity issues. If i run it hard and high in the rpms it does fine. However, if I lug it in fifth and stand on it I have a turbo issue. It will build to about 20psi then the boost pressure will start surging until it climbs over 30 -35 psi. I thought Imay have a fuel issue, so I installed a piston lift pump and I still have the issue. I'm thinking my turbo may be the issue. If so, does anyone have any suggestions on an affordable upgade? Thanks.
Old Mar 11, 2011 | 10:09 PM
93-12Smoke's Avatar
Turbo to small?
Old Mar 11, 2011 | 11:44 PM
92smokin blacky's Avatar
HE351CW, enough said, it will clean those pods right up.
Old Mar 12, 2011 | 11:48 AM
cougar's Avatar
Crank your star wheel up, your smoke screw up, and your fuel screw out.
Old Mar 12, 2011 | 12:29 PM
blackfordd's Avatar
"smokinblacky" is right on. I did the same as you "blue" and followed "Blacky's" lead with the HE351cw.
https://www.dieseltruckresource.com/...d-t286649.html
Old Mar 13, 2011 | 07:23 PM
blue92's Avatar
Thanks for the help. What year of truck can I find that turbo on? Is the mounting flange and oil supply and drain the same? What did you do for a downpipe? I'd like to know what all i need to acquire. Also, would my turbo be any good for my 94 truck?
Old Mar 13, 2011 | 11:30 PM
Search HE351 and you'll find all sorts of info, They came on the 04.5-07 dodges. Oil lines will match up fine, you'll need a 4" flange for downpipe, yes it would work good on any year truck I think, it would be a good upgrade for a 94.
Old Apr 1, 2011 | 03:21 PM
blue92's Avatar
I've been looking for and HE351CW and they seem to be in hghly sought after. Would the be a good substitute? HX40W or S300. As far as size I'd prefer a 60mm, but how would a 56mm do? I've found a 60mm HX40W with a 16cm3 housing. Yay or nay?
Old Apr 1, 2011 | 03:36 PM
dieselJon's Avatar
HX40's cannot take abuse of quick throttle let off when under ful boost. Snapped shafts. So if you can slowly (slower than just letting off in a second) let out of the go pedal, then it will be fine.
S300 based turbos are the cats meow but a little spendy for one built for a truck. Once you have one though, it can handle a lot more abuse than a HX40.
jmccart
Oct 8, 2007 11:20 PM
desertchecker
26
May 2, 2007 09:48 AM
D.Wiggs
18
Jan 15, 2007 10:55 AM
D.Wiggs
37
Dec 19, 2006 06:08 PM
mysterync
Apr 21, 2006 11:28 PM
