Door Structure Upgrade... Thanks Wheelieking !
It did look like T-man mentioned using LESS than 5/8s because of needing room for the speaker. I am assuming installing, removing or replacing the speaker was the problem.
I will see what sort of material I can find and report back as to how it worked.
That is why I asked. I read every post on this thread and then asked.
The horizontal access opening is now 5/8" smaller. With the big 6x9 speaker having a huge magnet (tall), vs the original one, I was concerned it wouldn't fit because of the magnet protrusion being so large. It wound up fitting fine, so no worries.
I'm sure better speakers have a shorter speaker depth anyway. Mine were just some cheapo Amazon speakers I picked up....
So I'm in for this- and thank you for the half on the tubing. I wasn't thinking about moving the speaker in/out, so I will make sure the path still works.
I do have additional door improvement suggestions.
1) add stiffeners to the outer skin. This will reduce flexing and reduce cracking @ the lower hinge plus it dampens the drum effect of the panel making the truck quieter.
2) The dodge engineer was saying that even with new hinges these just hammer out the bushings. Well, they are using leaded-bronze bushings which are soft. Can switch those out for some Aluminum bronze bushings and they should last better as it's got 3 times the strength in bearing. My plan is to measure the bushings in the help kit and just go procure some NAS equivalents.
M
M
I bought a 4 FT strip of 1/2 square stock to try on a door.
I will start with the driver's side of Poncho, my 91.0, which is not as mint as my RC. I will start there so I can learn any tricks doing it that I want to do on the next door. I would like to have a good game plan by the time I do the doors on my RC.
It was just the standard stock for sale at the hardware store locally.
It looks like 1/16 of an inch or so thick using a tape measure. It seems plenty rugged enough to add the door structure I am looking for without adding too much weight. I will post up the results after I get a chance to install it.
I plan on starting with a door that is manual with only speaker wires and a speaker in it other than the glass.
I plan on leaving the door full of components and just blanketing the speaker with a fire proof layer and cranking the window up for the welding part.
I figured I would start on my '91.0 with manual doors and see how it goes, before I do my RC with power doors.
It wasn't used in my truck, but I would assume it's a centering or location point for when the factory where the door was assembled mounted it to a jig, for the machine to weld up the skin / carcass of the door
Tomtt
Aug 12, 2008 10:53 PM
svmopars
Oct 27, 2004 06:35 PM
Chazman
13
Jul 20, 2004 03:04 PM
