Do you think one could retrofit this?
Old Jan 20, 2008 | 09:39 PM
MikeThomas's Avatar
So im bidding on this for fun:
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
Anybody know whats different inside? Seems like a good source for parts? I see the kill lever is on the engine side...any thoughts?
Old Jan 20, 2008 | 09:47 PM
vzdude's Avatar
DTR's 'Go to Guy'
I think that is only a two speed pump. Not a variable, like would be needed for a vehicle. I'm no expert by an means, but I'd wanna know for sure!
Old Jan 20, 2008 | 09:56 PM
bobva's Avatar
change the top end with a dodge cummins top end should fit
my pump is a cross between a yardog and a dodge
Old Jan 20, 2008 | 10:27 PM
bobva's Avatar
head is too small its only a 10mm.
dodge cummin is 12mm
but I thick you can make it fit
Old Jan 21, 2008 | 04:50 AM
When an Ebay seller tells you not to use the pump on your truck, that ought to tell you something.
Like vzdude said, the governor is unsuitable for our use.
Old Jan 21, 2008 | 05:59 AM
JD730's Avatar
That pump has a min/max governor in it. Not technically a 2 speed. It very much like a P-pump governor on the later trucks, once your off idle and below the max rpm setting the throttle position and fuel collar are more tied together than the governor in our trucks.
The head is 10mm and the rotation is correct for our engine. You could make it fit, but why short yourself like that.
I wouldn't say the governor is unsuitable, I would say the 10mm pumping element might not be enough. On that note, I saw another ebay VE I was watching sell for something ridiculous like $600. The pictures of the pump weren't even close for a 6B application, it was mounted on the other side and had a different main case. I has asked for numbers and when I decoded it I found the rotation was opposite of what was needed, etc... Whether I should or shouldn't have I sent the buyer a message explaining that to him.
I have a thought, that pump is for an Onan L634T otherwise known as a Cummins 6AT.
Here's a good site for looking up the application for bosch VE pumps. http://www.vepump.cn/CZB.htm
Old Jan 21, 2008 | 09:04 AM
pwrtripls1's Avatar
I know the 3.8L volvo penta marine diesel uses the same bosch ve pump. they are rated at 230hp@3800rpms though. I have one that was rebuilt and has a couple hours on it in my garage for parts.
Old Jan 21, 2008 | 09:05 AM
pwrtripls1's Avatar
I wonder if its the same pump BD uses for there 230hp version.
Old Jan 21, 2008 | 09:25 AM
JD730's Avatar
Originally Posted by pwrtripls1
I know the 3.8L volvo penta marine diesel uses the same bosch ve pump. they are rated at 210hp@3800rpms though. I have one that was rebuilt and has a couple hours on it in my garage for parts.
What are the numbers on it? It might not even be the right pump case or rotation.
I doubt it, I'm sure BD is just setting up the normal pump with higher fuel rates via the full power screw.
Old Jan 21, 2008 | 11:27 AM
MikeThomas's Avatar
Yep had a feeling. It will be fun to dissect though....
Old Jan 21, 2008 | 11:48 AM
pwrtripls1's Avatar
its an identical case and rotation. even mounts nearly the same place as the cummins. i dont recall the numbers on it, i will look when i get home. i still have the overhaul manual for that pump somewhere in a box.
Old Jan 21, 2008 | 12:03 PM
pwrtripls1's Avatar
Technical data
Engine TAMD42B
Production period 1993-1996
Operation 4-stroke
Cylinder configuration 6
Bore (mm) 92
Stroke (mm) 90
Compression ratio 17.8:1
Displacement (litres) 3.59
Power (hp) 230
Max engine speed (rpm) 3900
Thats the specs on the engine from volvos site. It went out of production in 96 i believe. I have had the injectors, pump, and turbo since then. Dont know why my wife calls me a packrat.
Flatbed24v
Jan 15, 2009 10:52 PM
Cam73
Nov 28, 2006 07:02 PM
cumminsdriver635
Mar 9, 2006 09:38 AM
strean
Feb 15, 2006 01:57 AM
