DIY-water/meth-injection
It takes more pressure to get a good spray out of the big nozzles. Use 2 or even 3 small ones. You want a mist that will evaporate instantly on contact with the hot air, not droplets.
So youre saying it would be better to go with a pair of 2.3 or 3.9gph injectors and just crank up the pump pressure for additional flow, if needed.
How necessary is the electric solenoid between the pump and injectors? I see that loch recommends it. Could you use like a 25psi check valve instead? Or could you set it up without anything at all?
the solinoid stops the water flow, it remains pressurized a good bit after inj shuts off, this really isnt a problem if you let it cool down, but if your tank isnt a good bit lower siphon effect can happen, its happened before that entire contents of the tank have drained into the engine,,,not good,,,
Originally Posted by rockjeep73
You think? haha, just trying to give you a hard time.
So should I go with two 3.9gph injectors, in an attempt to duplicate Snows setup? Or smaller injectors? Would there be any benefit to using one large injector?
One more thing, does anyone have a source for the push-lock fittings and line, like the stuff that comes in the snow kit?
Thanks
Thanks
Thanks for the info, heres some links if anyones intersested.
http://www.waterfilterstore.net/cat.asp?i=101
http://www.purewater4u.com/store/jg.shtml
jdpiii
Jun 19, 2008 07:34 AM
BossHogg
Oct 23, 2006 04:25 PM
