Dipstick pic- does it look okay?
Just picked up this 90 cummins and dude never changed the fluids. Oil looked muddy almost and felt tacky and thick. Changed the oil and it looks like this. When you touch it with your finger it comes off yellowish but on the stick it looks straight black. Couldn't be a head gasket could it? Have new injectors on the way that should fix it running rough. Any ideas guys?
I would be tempted to run it till warm, then drop and change just the oil and see how it does the second time around.
You might be dragging all the much up into the oil.
How long has that oil been in it?
It is also kinda thick when cold.
Yes his words were, " it could probably use some fluid changes, cause I don't do that stuff " Lol and the pics were taken right after doing the oil change and running it for a minute. I have new injectors on the way and that should fix how it's running, if not I know I have another problem
Did you use 15w40 oil? It is normal for the oil to turn black quickly. Mine takes over 1000kms to get black but I've heard of others turning black as soon as they start the truck after an oil change.
You might want to check the valve clearances if the engine has some miles on it and hasn't been maintained properly.
And yes fresh shell rotella 15w40 conventional. If these injectors get it on the road I planned on putting 500ish miles on it and doing another. I'm not concerned about the color as much as the bubbles. I've heard bubbles means bad things
i'd say as long as it's not foamy/frothy i wouldn't worry too much about it.
i recommended the synthetic because it will clean up things that conventional will leave behind. which sometimes is good or bad.
I agree with the others...if it had been neglected for a long time there is most likely a lot of sludge in the motor. It's going to blacken up super fast!
I'd change the oil like you suggested, after a 500 mile trip. Then I'd do it every 3 months for the next year or so, or until the oil starts looking more "normal".
My 89 motor I had in my crewcab used to turn the oil black within a 1000miles or so, but my 93 motor I now have in the crew will just start to turn slightly brown-sih, from clear oil, at 5000km's.
Here's something we did when we had a programming problem on some new Common Rail engines back in 2006-2007. They would root the oil up WAY too fast, and would cause valve bridge and rocker arm wear like you wouldn't believe. This was a Sisu Diesel sanctioned fix, that I have used many times in the past, and since then.
Fill the crankcase half full of diesel, and half full of oil...and for good measure, install a manual oil pressure gauge in the filter head just to be sure.
Fire it up, and run it at 1500-2000RPM until the oil pressure drops to 20psi, or the light comes on...Drain.
Repeat this 3 times.
Fill with new oil, change filter, and go. This does an excellent job of cleaning out a LOT of old sludge from the engine.
You can use it if you like, just throwing it out there for you.
Chris
Chris
Chris
Chris
