Differential Oil Question
Any reason that I cannot use 85w-140 HD oil in my differential I believe Dana called for 90-wt.
http://www-static.shell.com/static/g...oil_85w140.pdf
The rep from Shell says it should be fine.
Here in Southern California it doesn't get cold.
Jim
Jim
I got 4 quarts of the Shell because it is severe duty, they said it is allot better than products like Sta Lube.
Anyone know if there is a magnet inside the diff?
Jim
Jim
I tried Synthetic 75W140 and had oil analysis run after 18,000 miles. What I found was that unless you do a lot of towing it retains a lot of water. Under normal driving 75W140 does not get hot enough to keep this grade of gear oil from building excessive amounts oil water and other soluable contaminants from building up. I have switched back to 75W90 and analysis show that the build up of water is not a problem with 75W90.
Bob
Bob
No magnet on the plug or inside the cover. The 7 pints (3.5qts) isn't enough to make the fluid come in contact with the plug anyhow. Might just stick a magnet near the bottom of the pan.
Were you on a level surface when you changed it? I've always been able to get the 3.5qts in there.
