death wooble
Old 07-01-2018, 04:59 AM
KRB
KRB's Avatar
I think the lesson here is there are many things to check and fix - which compounds/complicates diagnosis.
maybe368 (07-01-2018)
Old 07-01-2018, 07:48 AM
maybe368's Avatar
KRB is correct, and always KISS, start with the simple and work on to the king pins...Mark
Old 07-01-2018, 11:03 AM
cougar's Avatar
True, true. Replaced and repaired a lot of stuff on my 91.5 and never fixed the problem, until I did the brakes. Diagnosis is the critical part, determining the actual problem is a bear on these trucks.
Old 07-07-2018, 04:41 AM
KRB
KRB's Avatar
You jinxed me!
I was starting to feel a "wobble" in the steering when turning right and going uphill while accelerating. Felt like a slipped belt.
Tuesday I turned right onto a highway and accelerated and the whole front end went into a wobble. I pulled over expecting to see a wheel hanging off but all was well. I did find a worn tie rod end which I've now replaced. It has done that a couple times since. I've jacked up the front end and can't find anything loose or off kilter...
Old 07-07-2018, 11:33 AM
cougar's Avatar
CV joints?
Old 07-07-2018, 12:39 PM
u2slow's Avatar
Replace any parts with obvious/generous play in them, and make sure you have at least 5° caster. (Stock/factory spec is not enough.)
I always run a basic single stabilizer on kingpin D60s. The one for Dodge D44's fits ok if you finesse the mounting ubolts a little bit for the 1/8" fatter axle tube.
nonrev (07-08-2018)
firebill1720
06-19-2011 07:03 PM
dr.caterpillar
17
08-13-2009 11:03 PM
stroker101
11-23-2008 07:38 AM
ozpall
02-22-2008 10:18 PM
vj_M
51
06-26-2007 10:46 AM
Quick Reply: death wooble
