Dana 70 rear axle seal part number
Hi guys, my rear axle seals are leaking and I am having a little problem finding the correct seals and a thread that I know has the numbers. I went to rock auto and they don't even list a dana 70, any help would be great, Thanks Mark P.S. And a shout out to Oliver Foster for being a great resource for hard to find parts for these trucks, Thanks a million Oliver
Are the seals for the 60 the same as for the 70? I cannot find anything about the 70, thanks ...Mark Would the 9,25" heavy duty axle be the 70?
First, what seals are you asking about? the hub seal? If so, no they are not the same. I had the same issue as you and finally took mine to a parts house and looked until we found the right one. The online places always gave the part number for the 60.
Vatozone Duralast 455086
I've never had any issue finding the hub seals for the Dana 70. Always just got them off Rockauto...I found it listed right away.
SKF 24917 Grease Seal Info One of our most popular parts
FitsFront; Spicer 44 w/ 3,500 lb Axle
OrRear; Spicer 60 & 70 Axles w/ 12" X 2.5" Brakes (Only 4 Remaining)
Thanks for the number. I am getting different results on rockauto for some reason, there is not 1 listing for dana 70. When I search the part number I get all kinds of results, when I search "dana 70 wheel seal" I get nothing, Thanks guys...Mark
Received 1,637 Likes
I had problems with 2 different listings for seals for my 92. Bought the wrong ones and they leaked almost immediately. Bought the other number, and I've been good since. The two sizes differ minimally. Od is the same. Id vary slightly.
My truck needed the slightly larger size. Even though both fit the spindle, the smaller size heats up and fails, popping out the little spring.
I have the part on the shelf in the garage. I'll post it In a little bit once it stops raining. Wicked witch of the East will melt away if I get rained on
99% sure it's
Timken # 417158
The other number 455086 fits, but is too tight on the spindle
99% sure it's
Timken # 417158
99% sure it's
Timken # 417158
99% sure it's
Timken # 417158
Not 100% sure, but the idea that two numbers exist leads me to believe that production differences caused this to be. Notations for rgwv show under or over. 9000 lbs axle weight capacity Dictate the seal used. My rear axle was replaced at one point by the p.o. this is why I had problems with the seals. It was necessary for me to buy both seals, and test fit them dry to determine the correct seal number., once I had both seal numbers, their specs off Timken website, and the drum off, I figured my truck out. The seal that I used, which leaked, was too tight on the spindle. The other number was my correct seal for my axle
The Dual wheel hubs and Single wheel hubs use different seals, just to be clear.
The few different single wheel hubs I have worked on all used the 417158 seal.
The outside diameter on the 455086 seal is 4 1/4", vs the 3 7/8" for the correct seal for a SRW truck . . . so I don't see how there could be any confusion there?
I did just install a National 37015a unitized seal on my right rear instead of sleeving the damaged spindle surface, but I don't have enough miles on it yet to give a report. The unitized seal does physically fit, but had to be seated fully in the bore as it is thicker.
And, for reference: https://www.dieseltruckresource.com/...-seals-148798/
I was sitting having dinner, away from my computer, and looking up on my phone Rockauto's website for the numbers. Without being able to access a timken catalog to review the physical sizing, I posted the numbers that I read were listed for Dana 70's, 71's etc. Been a couple years since I looked up numbers for my rear axle, and I don't keep a notebook in my wallet regarding parts for my dodge.
Mark needs to confirm the seal fitting correctly, regardless of what I, you or anyone else posts here, as it can vary, especially when you get a truck like mine which had the rear diff replaced in it's past.
I also stated that I had the seals in my garage which fit my truck, which I would get back to, So here's what I said I would do, which is post the numbers of the seals that fit MY truck. The top of a box I ripped off 6 years ago, and the stock I keep for future replacements.
Mark needs to check to make sure they're correct.
And yes you were right about the 455086 being way too big.
There's also a picture of my wife's dinner, just to prove I'm not BS-ing you Alec....
A good read from the seal manufacturer.
I never knew you were supposed to lube the outside of the seal prior to install. I've either installed them dry or with some sort of gasket maker.
Loin somethin nuu ebery day..
So,
Alec got me thinking...
(Thanks Alec)
Why was my axle leaking when I bought my truck ?
So I figured it out by going to Timken's website.
My dodge, when I bought it had rear seals just put in, and by the time I got home, gear oil was leaking out.
They had # 415009 in the rear hubs.
So, when I replaced them, I put the same number in there, which also failed. I just handed the dude at the parts store the seal, and he gave me a new one.
This is when I went to the catalog to find out why, I realized that they installed a front Dana 60 grease seal, on the rear of my dodge, vs the correct 417158 oil bath seal.
They're almost identical in size (same outside diameter), but the 415009 leaked immediately after replacement because it fits a slightly smaller shaft (hence the reason why it heated up, spit the metal spring out, and failed)
Thanks Alec for refreshing my old, decrepit memory...
(Thanks Alec)
99% sure it's
Timken # 417158
99% sure it's
Timken # 417158
