Dana 60
Old 10-16-2018, 07:14 AM
Ol-dodge 1992's Avatar
Thanks for the pictures Dave
Your tool looks like a very simple fix to a messy job
I'm gonna fab one of those up and give it a try ... next time I'm inside my front hubs ... which will be in spring time when I address the kingpins
Thanks again... if I can figure out how to post the picture I'll do it but I never can post them as I use the mobile app for DTR
SD
Old 10-16-2018, 07:17 AM
nonrev's Avatar
DeathRowDaves tool
This is a tool I made to grease the spindle bearings without removing the spindle . You simply screw this onto the spindle over the axle and use your grease gun to grease the spindle bearing . I made the tool from an old spindle nut , a black iron pipe nipple , a coupon from a hole saw 1/4 in plate and a grease fitting . It works great and saves a ton on time during maintenance . Thanks so much for posting , as I said I can fix , anytime except my stupidity , not being able to post . Thanks again and be safe , Dave
Old 10-16-2018, 10:53 AM
bannerd's Avatar
interesting, that is sort of what I had in my mind. Did you drill a relief hole in the seal or does it just press out?
Old 10-16-2018, 08:29 PM
death row dave's Avatar
I just grease until resistance is felt . I try not to bypass the seal, no relief hole . I always use moly grease to lube spindle and wheel bearings . Not sure if that is correct or what everyone else chooses to use , I picked this up from servicing my M35A2 years ago , Military Specs . It will not hurt anything if you do bypass the seal . You can tell by resistance on the grease gun when the spindle is nearing full . Works great . I built one for a Dana 44 and a Dana 60 . They are very rarely in my tool box , on loan to someone doing maintenance .
Old 10-20-2018, 09:01 PM
mhuppertz's Avatar
Originally Posted by death row dave
I made a tool from a spindle nut a piece of black iron pipe , a welch plug ( freeze plug ) , and a grease fitting . You can screw the tool onto the spindle threads and use a grease gun to pack the spindle and bearing full of grease easily .
I need a picture of that!
Old 10-20-2018, 09:18 PM
Received 2,392 Likes on 1,576 Posts
Mark, look above for a picture of it.
nonrev posted one on the 16th.
tankeryanker
14
01-19-2005 04:18 PM
Mechanos
01-22-2004 12:45 PM
matthopp
11-21-2003 04:49 PM
mcevins
07-03-2003 02:06 AM
Stamey
04-18-2003 10:34 PM
Quick Reply: Dana 60
