D60 inner axle seals?
Are their inner axle shaft seals on either side of the carrier on our Dana/Spicer 60 front axles? I have not seen them on any parts break down and I have a leak.
Thanks
Arg! So let me guess, I gotta pull the carrier to get them put.
Yes you do.
Putting them back in is fun also. I found the socket for the front wheel bearing nuts. The taper at the top of the socket for the drive fits the seal perfect. Just put an extension in from the open end of the socket and drive the seal in. Putting in the passenger side seal requires a 5' extension. My wheel bearing socket is a snap on.
Also, is that bell to guide the shafts in without messing up the seal?
I tried a pair of those two piece seals you see on ebay. Do not waste your money. The outside OD of those seals was larger than the ID of the axle tube. They wouldn't work and no chance of getting a refund. The clown wouldn't even return a PM. Plus ebay doesn't let you leave negative feed back anymore. So epray lost my business.
The bell is used to guide the axle shaft threw. The passenger side you can use a regular seal if your care full on install of the axle shaft. The drivers side needs that bell. Want to ask my how I know.
