Custom Dash Pod - project
Old Feb 8, 2005 | 03:50 PM
That's nice! You ought to have it Line-x'ed in dashboard color, that would look good.
Old Feb 8, 2005 | 05:12 PM
Den's Avatar
Den
Thanks everybody!
As for the shaping, the pod is made out of 1/8" aluminum. All the edges were put together corner to corner leaving a nice gap to fill in. I then took a 100 grit flap wheel on a 4" grinder and knocked down the welds. Then DA in stages 80, 180, 320. The trick is to lock the DA so it spins and then shape that way for the most part. Takes some practice to make even edges.
All the pieces had the correct shape and any places where it was butt together were beveled then welded so I could finish it without if falling apart. Posterboard is excellent for making templates for wierd side peices and curves. As seen on TV lol
For the coloring...We were talking about the line-x today. Then a guy at work said he can epoxy prime it and get a splatter like texture that I could knock down a bit with the DA. Wondering if I can still get dash color from Dodge..or maybe the local paint supply house. Also talked about getting it wrapped in something.
Think I should make it tan to match the interior and then make a thin face and woodgrain it to match the dash? Or just tan?
Den
Old Feb 8, 2005 | 05:58 PM
G1625S's Avatar
my vote's for just tan
Old Feb 8, 2005 | 07:52 PM
charger 69's Avatar
sssssssooooooooooooooooooo when are you going to put a price on them and put it in production????
Old Feb 8, 2005 | 08:15 PM
spunbearing's Avatar
I thought that it was tig welded stainless. Aluminum is cool too and much easier to work with.
Old Feb 8, 2005 | 09:50 PM
Den's Avatar
Den
Maybe in the future I might make a few items at a time and sell them. Have a couple of items i'm thinking of making limited amounts of to sell. A high capacity diff is sitting here in the planning stages with drawings almost ready to go to the CNC router. Actually all I need is to decide if I want the fill on the side or back. Side is winning out for proper oil level reasons since the back is farther out. Also a possible oil pan with all sorts of spots for custom turbo drains, temp sensors, etc.
I'm doing so much stainless boat railing at work since the hurricanes...well...i'm sick of working on it. Constantly splicing 2 peices of SS tubing for a top rail together and filing, sanding, buffing to make the joint disappear gets tiresome I don't mind the coped parts too much. Stainless on off hours would be torturing myself at this point
Den
Old Feb 9, 2005 | 10:19 AM
Alec's Avatar
I vote against the wood-grain . . . Indeed, I think it is a shame to cover up all of that fab-work at all. If you were going to paint it, you could have just done it in resin . . .
As for the diff cover, I think the side is better for the fill -- more protected.
Very jealous of your work. It looks really good.
Alec
Old Feb 20, 2005 | 06:06 PM
Den's Avatar
Den
Well..it's painted and installed in the truck. I didn't take shots of the Unibit going through the dash to prevent anyone getting sick I also took another 3/8" off the bottom to make it lower.
Going with all mechanical gauges in there was a PITA. I had to bend the tubes coming out of back of the trans and water temp just to get them to fit in the pod. So much for the dimensions I used from the site.
The tee and fittings I used for the tranmission sensor is leaking. I used a fitting that had a flared piece that went into the end of the tubing. No flaring. I think I need to redo that. I telflon taped everything when I put it together. It's a seeping leak..but a leak.
It looked like my thermostat was stuck open on the way home. Both the stock sender and the guage were reading like it was open all the way and no cycling. Ran very cool.
My max boost is in 2nd gear and it's only 14#. That was mashing it up a bridge. Kinda disappointed with that. Never saw the ET go over 1000F. Probe is in the manifold. No cruise boost at 50 mph. The intercooler and boots have been checked previously. I do know the o-ring for the turbo is smooshed in one part. I guess I need to get a new one. I also replaced the ex. manifold/housing steel gasket.
Den
Old Feb 20, 2005 | 06:48 PM
Looks nice! I hope you're tall.
14 psi is pretty normal for a stock intercooled truck. 12 - 16 is pretty much the normal range. You shouldn't have boost on flat ground at 50 with the stock turbine housing. Even with the 12 cm I have around 3 psi. All you need is a smaller turbine housing and more fuel, 1000 degrees is nothing.
Old Feb 20, 2005 | 07:13 PM
Jim Shulmister's Avatar
Muted User
Where are you....florida?
-Jim-
Old Feb 20, 2005 | 07:51 PM
Den's Avatar
Den
WD
Cool on the specs. It's definately getting turned up once the leak is fixed and I change out that t-stat.
As for the height, It's really not that bad sitting in the seat. It's a little in your face at first , but i'm getting used to it. <must keep eyes on road...must keep eyes on road>
Jim...Yup! < points to left of this post > Cape Coral
Den
Old Feb 20, 2005 | 08:38 PM
jive55's Avatar
Thumbs up
AWESOME JOB !
plcnut
Jun 14, 2010 07:36 PM
NoSparkplugs
17
May 17, 2009 10:36 PM
BrokeSolid
21
Feb 3, 2009 09:36 AM
enydick
Mar 24, 2008 01:42 PM
scarecrow
Mar 9, 2006 08:12 PM
