Cruise control runaway? TPS-CPS sensors? Settings?
Well we changed to the 3k governor spring and did some more work on truck! Installed the 16cm housing! Well here is the problems we encountered-need a air gap setting number for the crank position sensor. Also the voltage for the TPS at idle. Here is the major problem-cruise contol is now at runaway-I set it and its speed increases about 15mph over its setting-so what do I do to correct this-any and all help would be appreciated-always-thanks in advance!
:confused: |
TPS should be 1.00v or slightly above at idle and at least 2.25 above that at max throttle
Measure at center wire..and don't lean on the battery while your using a paperclip to get a reading ..You'll get funky results..trust me ;) Adjust by turning the shaft on TPS. Underneath it using a small wrench..it's either 10 or 12 mm Den |
well its higher!
Checked it out at idle and its about 2.7! What next?
| All times are GMT -5. The time now is 02:00 AM. |
