cruise control
cruise control
cruise works when it wants. but i have found the culprit. under the horn is a connector that Y's off: there is the main connector feeding it (from the clockspring i believe) and then it Y's off to the "on/off" and the "set/resume" controls. my "set/resume" is acting up. i pulled the rocker switch off and can push on the wires (not the buttons) to make it work. is just this Y connector assembly available for purchase or does the whole clockspring assembly need to be purchased? dealer showed nothing for the Y and the clockspring schematic didnt show the Y or mentioned anything about it. and nothing in stock to look at.
if the entire assembly needs to be bought, its off to the junk yard.
thanks, Pat
thanks, Pat
Try www.chryslerpartsdirect.com I've had good luck with them and their prices are generally less than you "loco" dealer.
Bob
Bob
Bob
Bob
i sent a comment with my VIN and noted that i had the 3 spoke steering wheel (i knew to do this after speaking with different dealers). response was my VIN says i have a 2 spoke and i was given a link to the part i need. the part that was linked was different than the two i found.
probably need to request more info. too bad they dont show pics.
Pat
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
