crossover help..
crossover help..
I am in the middle of taking my front end apart and cant seem to find a pic of the 2wd location to remount the box. I couldnt find a write up on installing crossover on a truck with a lift.. Can anybody point me in the right direction?
Thanks!!
Thanks!!
Uummmmm, always check the sticky first....Its under steering section and crossover near the bottom. There is a pic of the box mounted in the 2wd location. Its the only other holes that it will mount too (you have to remove the plate between the frame and box).
https://www.dieseltruckresource.com/...t-t102027.html
https://www.dieseltruckresource.com/...t-t291427.html
Thank you! I started to read the post in the sticky but it seemed like it was for a different application.... I got it all in and working along with a borgeson box and shaft.... WOW what a difference!!
i installed a stabilizer setup when i first bought the rig... it helped a bit.. just replaced all of that along with the crossover and borgeson box and shaft... aaaannd the new fluidamper.. one descriptive word for my truck i never thought i would use... BUTTER .
by far the most impressive mods
Forrest Nearing
Dec 7, 2004 07:32 PM
shortround
Oct 29, 2004 09:09 PM
