CPS Sensor Replacement
Old Mar 6, 2023 | 09:59 AM
austin004's Avatar
After a year of hunting down a charging problem (wait to start light stays on, and the alternator does not charge), I hope I've finally found the issue. After replacing the Alternator, Battery, Grid Heater, Grid Heater intake sensor and relays, a new Engine bay wiring harness and installing a voltage regulator, I believe my CPS sensor is shot. I was able to loosen the 3 bolts holding on the CPS sensor and re-gap the clearance but still no charging.
My question is, how can a person change the CPS sensor, there is not enough clearance to remove the bolts without hitting the fan, does the rad and fan need to be removed? and is it worth doing the KDP at the same time?
Old Mar 6, 2023 | 10:03 AM
IIRC they are held in by studs with nuts on them.
The only CPS sensors I have changed are on motors that are not buried in an engine bay.
Old Mar 6, 2023 | 03:50 PM
I have an aftermarket fluidampr and their brackets for the CPS and I can get it on/off by just removing the fan, so I would think that is all you would need to do to get an OEM CPS off to replace it.
virginiaram
Jul 20, 2012 04:50 AM
crowderfarms
Aug 28, 2008 08:01 AM
triple 4
Apr 14, 2008 05:48 PM
zeeew
Jan 25, 2007 09:47 PM
adamroofer25
Apr 25, 2004 10:29 PM
