A Country Cummins - Build Thread
its original lamps. just wrapped the lenses amber
Looking good man!
nothing special about this fabric. and actually it sucks to wrap with. it's really thick and has no stretch. makes things really hard!!
thanks! its honestly not bad at all. it was just a huge change at first
depending on what im wrapping a variety of different glues. the upper door panels are one kind, the lower panels another, the dash another yet, the head liner another yet. Just depends on the application. varies from anything to hot glue, to loctite spray ahesive.
Well my wiring is so freaking screwed from head to toe. this is going to be a NIGHTMARE. my headlights/park lights only work when they want too for no rhyme or reason. my turn singals dont work at all, except sometimes all 4 flash! stereo doesnt work, horn doesnt work, windshield wipers dont work, passenger side window/door lock switches dont work, but they operate from the drivers side. truck doesnt always shut down when you turn the key off... i could seriously go on... its a nightmare. i guess next project is completely rewiring the truck from head to toe. I'll probably end up buying a painless wiring kit for a hotrod and adapting it into the diesel and be done with ever thing those crappy dodge engineers did in there.
but on the bright side, my gauges look pretty lit up. haha.
also wondering if i ground the fuel pin enough, or if i should go a little more? any insight from the pro's out there?
You need the grind the pin farther up.
i know ive got bad grounds but I've got bigger issues than just that. besides the mud that replaces some fuses you have hack job wiring from the previous owner. dead end wires going no where and some wires missing completely. its a terrible mess and its really starting to get worse the more i try to clean it up
