Coolant leak
I’m gonna double check before I get busy with a repair! I have done a coolant pressure test and found some hoses that needed clamps tightened. The system does have a leak under pressure with the engine not running! I’ll keep you posted!
Thanks!
Thanks!
Ok,
instead of giving you ways to scoot around removing the engine and or trans, I am going to agree with everyone above and say that you should use an inspection mirror or cam to identify the leak on your bell housing etc.
I have been able to pry into a rear freeze plug but I was not successful in replacing it while the engine was mounted head removed trans in place.
if you are replacing gaskets might as well remove the engine and handle the upper and lower gaskets if you haven't tabbed the kdp do so then.
locktite the bolts on the timing cover. wish you the best of luck take pictures post them and keep us all informed of your progress.
thanks to everyone on this site i've learned a plethora of information I would and would not of known.
cutthroatxxx
17
05-22-2015 07:09 AM
george7941
11-28-2009 09:28 PM
Mark Hodowanec
08-17-2009 11:56 AM
