Coolant Filter Addition: Is it worth the cost?
Old Mar 15, 2011 | 03:03 PM
Rancher99's Avatar
Hey Guys:
I am in the process of putting a coolant filter on my 91 per the instructions in the sticky.
I got the base ($24) Filter ($14 cummins) and fittings/hose (125).
Is a coolant filter worth $170 on these first gens?
I kinda want to know BEFORE I put everything on.
Andy
Old Mar 15, 2011 | 03:53 PM
dstad's Avatar
Its all a matter of prespective if you ask me. If its your dd or go fast truck why not have a little bit more pretection. Radiators, and heater cores arent anywhere as cheap as 140 filter set up. Just my $0.02
Old Mar 15, 2011 | 04:05 PM
Trebor's Avatar
I use distilled water, antifreeze, and corrosion inhibitor which has performed without any problems in all of my present and long time owned diesel engines including the one in my highlift. Change the coolant every few years and you won't need a corrosion inhibiting filter set up.
Old Mar 15, 2011 | 07:07 PM
ARbowhunter7's Avatar
Originally Posted by Rancher99
Hey Guys:
There's a reason that all the big diesels have them...because when an engine is that important, they're worth it.
Old Mar 15, 2011 | 07:15 PM
AH64ID's Avatar
I have one on mine. It's not as important on non-sleeved motors but it sure can't hurt!
Old Mar 16, 2011 | 08:50 AM
Partsdude's Avatar
I installed one on my truck as the previous owner was not up to snuff in the maintenance department. The coolant was a dull brown and I can see scale build up on the fins inside the rad.
Old Mar 16, 2011 | 01:54 PM
jesussaves's Avatar
i just did mine and i didnt pay anywhere near 125 for fitting and hoses?
Old Mar 16, 2011 | 08:23 PM
NE frmhnd's Avatar
If you want to put one on, watch fleabay for a coolant filter for an International tractor model that ends in 66 or 86. Last I payed any attention, they were a lot cheaper.
wvopowered
Feb 10, 2010 10:42 AM
fflarry
Aug 7, 2007 09:32 AM
Lark
Mar 6, 2007 05:37 PM
rharveysr
Jul 18, 2003 01:05 PM
