Code 41 and 45
Old Aug 7, 2009 | 03:29 PM
PADuallyBoy's Avatar
Code 41 and 45
My truck is throwing code 41 (Generator field not switching properly)
and 12 (Battery connection disturbed within the last 50 starts) from the CEL, would you say that it's the alternator going bad?
Old Aug 7, 2009 | 04:56 PM
I'd swap the ASD relay for the A/C relay first.
Old Aug 8, 2009 | 12:31 AM
What you mean?
Old Aug 8, 2009 | 08:24 AM
Philip's Avatar
There are three relays mounted on the inside of the left fender. Swap the relay closest to the battery with the one closest to the hood hinge.
If you problem goes away. Replace the bad relay. If the problem doesn't go away let us know.
Old Aug 8, 2009 | 12:40 PM
So, i switched the relays around and then went junk yard hopping today and the light still came on, but on my way back from Lebanon county my radio kept turning off and on, and then I noticed that my voltmeter was low on the dash. So I drove with no radio. When I got home I took a voltmeter to the battery and it was putting out 9.75 volts and then I tested the alternator and I didn't even get a reading. So yeah
Old Aug 9, 2009 | 10:57 AM
GOT IT! One of the therminals on the back of the alternator had broke so I disconnected that part of the wire harness and resoidered it, check engine went right away!
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
