-   1st Gen. Ram - All Topics (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/)
-   -   cleaning melted piston from turbo (https://www.dieseltruckresource.com/forums/1st-gen-ram-all-topics-93/cleaning-melted-piston-turbo-125852/)
65fury Nov 29, 2006 08:11 PM
hey guys i was wondering if there was such a solution to cleaning the melted piston material out of my turbine housing. when my piston melted it push molten piston material all through my exhaust manifold and thinnly coated the in side of the turbine housing[verymad] , it suprisingly did not ruin the turbine blades[coffee] and the turbine blades still spin freely without any catching, but the turbine was a brand new 12cm non wastegated turbine housing and i want to keep if possible. so does anyone know of a chemical than cleans whatever the piston is made, off cast iron???
2stroke Nov 29, 2006 08:24 PM
we used to use muratic acid to clean aluminum out of 2 stroke jugs.
John H Nov 29, 2006 09:20 PM
Many, many years ago in a past life, I used to work for Holset. We used to clean the returned turbine wheels and housings with a caustic solution. The turbine wheel is made of Inconel and the turbine housing is made of ductile iron which are not easily attacked by the caustic, but it dissolves the aluminum. Don't let it contact the low alloy steel shaft.
Sheff
65fury Nov 29, 2006 10:32 PM
whats the name of the caustic solution, or is "caustic" the name[duhhh]
BearKiller Nov 30, 2006 12:20 AM
Stove-top home-made gun-bluing solution, the recipe that used to be in the old Dixie Gun Works catalogs, will dissolve aluminum on contact, [director] volcanically.
Don't ask me how I know this.[coffee]
I do remember that Sodium-Nitrate fertilizer and Red-Devil lye were two of the key ingredients.
