Check out chickenfarmer's Dodge!
#46
By the way, here was tonight's project. The old sill plates were all nasty and corroded and what not, so I used some scrap diamond plate I had around and made some new ones! They turned out better than I expected to tell the truth.
#47
Truck.
#48
Well I've been driving it for two weeks now and I absolutely loved the throttle response I was getting. This thing is fast as nuts! Haha until I found that I got 10 mpg on the first half tank! I can not afford that! So I made sure my fuel pin was at stock setting and backed way up on the smoke screw and star wheel. I am now only getting 13 mpg. Does anyone know where I can find the stock settings for the pump? I'd really like better milage than that, and yes I know I gotta keep my foot out if it. Thanks!
#49
I was getting 20+mpg driving a 400+hp motor in a bigger wind break, heavier truck than any stock first gen out there. Driving habits play a massive role. In the winter, driving only short distances absolutely kills fuel mileage. Winter fuel is often good for a couple mpg loss as well.
I'm not sure which trans you have (auto or stick) but the auto seems to do kind of poorly as well in the winter.
What I'm getting at is it may well not be the pump tuning. It may be any combination of your right foot, winter fuel, colder outside temps, shorter drives, maybe even low popping injectors. etc etc.
#50
Thanks Rick, that's good info to know, it is an auto and I drive less than a mile to work and back everyday, and of course it's like 15 degrees over here! I do think my pump can be turned down some still though
#51
As has been mentioned, there are a lot of other factors that can waste fuel. Engine temp control for instance, and the often mentioned lead foot.
#52
Diesels are funny. As long as you're not making a huge amount of smoke, pump setting doesn't seem to affect the mileage much given the same conditions. Some of the best mileage trucks I know of are beasts when it comes to pulling a load. Driven gently, they sip fuel.
#55
Brighter bulbs are hotter, and they can cause plastic parts to deteriorate rapidly. I'd stick with the stock spec, or go LED.
#56
more power to a point can produce better mileage if driven correctly. but where is the fun in that?.
If you do change any pump settings only do one at a time so you can easily go back if the result isn't what you expected.
#57
#58
I've been kicking myself for years over a '73 crew I let go by. I'll see how much they want for the lights, maybe the holiday break before I can get there again though.
#59
I found this '73 crew on Prescott, AZ Craigslist this summer. There's a story in itself just getting it here.
Sorry for the thread-jack, Chickenfarmer!! Love the truck!
#60
For example, my truck normally cruises at about 3-5psi boost. If I just hop in it and drive when the truck is cold and it's cold outside, it takes 10+psi to cruise the same speed until everything warms up (which usually takes 10-15 minutes of hwy driving to do). It's surprising how much harder the motor has to work when everything is really cold. And how inefficient it is when it's cold too. These motors love their heat, it helps the diesel burn more efficiently. That's why I run a 195F thermostat.
RAMMINVA
Competition / Pulls / OffRoad
13
11-17-2006 12:43 AM
Rocket95
01-13-2004 10:45 PM
SpitDirtCom
03-27-2003 08:06 AM
