Cheapest upgrades to up hp in 1rst gen?
Old Feb 23, 2003 | 01:40 AM
CruisingRam's Avatar
I am a total newbie to diesals and diesal performance, been building mopar gas motors forever though.<br><br>I want to do some upgrades to my motor, sure wouldn't mind being in the 300 horse range. It has some kind of gale banks exhaust system and intake filter/ fuel filter that is aftermarket, K&amp;N markers on them. Otherwise I think it is stock. <br><br>Is there a bolt on pump that gives more power? <br><br>I am not sure if I want the propane injection unless I can find a good place to mount the tank.
Old Feb 23, 2003 | 04:44 PM
Craig93's Avatar
Re:Cheapest upgrades to up hp in 1rst gen?
A good question, don't know why there are no responses yet, but while you are waiting you might find the answers to your questions in one of the previous posts, try a search or just read through some old posts, good reading regardless...<br>But from what I have gathered opening up the exhaust and making it breath in and out easier is a good place to start, and making some adjustments to your existing pump vs replacing it will add some hp and torque numbers, details are in the old posts....I would like to try tinkering with the pump but do not know enough about the effects on longevity or reliability, can't afford to compromise either at this point.
Old Feb 23, 2003 | 06:39 PM
midwestdually's Avatar
injectors...turbo...i am no expert...so others will chime in as well
Old Feb 24, 2003 | 12:59 AM
Bushy's Avatar
Patron Saint of 1st gens
Lets assume you want 300 RWHP, that is daily driveable fairly decent EGT's and modest smoke...
You will get as close to that as possible by:
Working your VE pump up near max. (no other options at this time, but you never know about tomorrow.
You will need an upgraded turbo, PDR HX35/16 perhaps
Cam
Increased pump timing
Big honkin injectors... POD's minimum
Oh, fully pressure tested intercooler
Some (to date) sneaky internal mod(s) to the VE
Now that doesn't sound like too much, but it is a challenge getting there.
You can get there with slightly less but now you're into high EGT's, high drive pressures on the turbo and other things. It would be a bit dirty.
On the up side, we're workin on it as we speak ;D ;D
Bob
Old Feb 28, 2003 | 03:56 AM
Thanks Bushy, keep me posted, go ahead and e-mail me if you got something new to tell!<br><br>What book do you recomend for a newbie to diesals in general, but only have interest in my cummins!
Old Feb 28, 2003 | 03:33 PM
Bushy's Avatar
The first book I'd hunt down is the service manual for the truck. <br>It's labelled:<br><br>Service Manual<br>D&amp;W 150-350 <br>Ramcharger<br>The number on the rear cover is: 81-370-3108<br><br>Next one would be:<br>Diesel distributor fuel-injection pump - VE (Bosch Technical Instruction)<br>It can be purchased on line and downloadable in PDF format.<br>This is a real good manual showing all the guts and workings of the VE pump we use on our trucks (they show a 4cl pump but it is the same as ours except for the 2 extra cylinders)<br><br>That will get ya rolling.<br><br>Bob
Old Feb 28, 2003 | 05:30 PM
ram91's Avatar
Before you start bumping up pressures rpm's etc get yourself some guages pyrometer shows exhaust temp 1250* max you want to go; tachometer so you know what you are runnig up to engine speed wise. boost tells you what your turbo is giving as input pressure into intake. then a big pocket book after you start down the slippery slope of bombing you baby. ;D bill
Old Mar 1, 2003 | 12:38 PM
I have the factory tach, how do I know which upgrades they have already done? There is obviously some parts on there that didn't come from the factory, the exhause, intercooler and air cleaner don't look stock to me. These mods had to be done pre-94 as well, when I bought the truck. I am re-doing allot of stuff on the truck, like paint job and body work, rebuilding tranny, and so now I am turning my attention to the diesal itself!
Old Mar 4, 2003 | 10:28 PM
cumminddg's Avatar
Dr. Performance makes an injector pump and injectors that add 85-100 hp there is one draw back though it costs $1995.00 installed. however with just a few tweaks to the stock pump that took me about 1 hr. i felt an incredible difference in power, i mean really good. check out http://dodgeram.org/tech/dsl/more_power/Power_ve.htm for more info on this. a 16 or even 14 cm housing would also make for great improvements. just my 2 cents worth.good luck anyway you decide to go.
Old Mar 4, 2003 | 11:04 PM
nascar mark's Avatar
[quote author=cumminddg link=board=9;threadid=11322;start=0#111766 date=1046838515]<br>Dr. Performance makes an injector pump and injectors that add 85-100 hp there is one draw back though it costs $1995.00 installed. however with just a few tweaks to the stock pump that took me about 1 hr. i felt an incredible difference in power, i mean really good. check out http://dodgeram.org/tech/dsl/more_power/Power_ve.htm for more info on this. a 16 or even 14 cm housing would also make for great improvements. just my 2 cents worth.good luck anyway you decide to go.<br>[/quote]<br>Save your money!!!!!!! Anyone can buy a set of injectors and tweak there pump and make as much or more power for the cost of $400 for injectors. Don't be taken.
Old Mar 7, 2003 | 04:03 AM
I am going to talk to my brother about this, I printed off the instructions from the link you posted , thanks! Will this kill my fuel mileage when I am at cruising speed though? I wouldn't think so right?
Old Mar 7, 2003 | 05:51 PM
cumminddg's Avatar
I just tweeked my pump a couple days ago but made a quick 500 mile round trip to Texarkana last night and averaged 16 mpg at 90mph and faster for the whole trip. In other words no I saw no decline in cruising mpg. Now around town if you drive like i do (foot to floor every chance I get) then you will probably see a mileage decrease. Thats the price to pay for never being embarassed by one of those powerjokes again. hope this helps make a decision
Old Mar 7, 2003 | 07:13 PM
furious70's Avatar
when i turned my pump up i went from 19mpg empty going 75 to 21mpg. when i put the 16cm^2 exh. housing on, it went to 22mpg.
Old Mar 9, 2003 | 01:26 AM
93w3504x4duelly's Avatar
I too am new too ctd but I own a few mopars,my truck is a 93w3504x4duelly extended cab 5spd 3.54 gears,I love it 19.5mpg in town no less I would like to Bomb it a little bit but I dont want too kill it or give up anything ether.I have all the gages in it so thats a plus, no cat or muff ether it also has a intercooler/turbo banks I think is the brand how can I tell? it has the stickers under the hood with the C.A.R.B.#s or if its stock? <br> <br>Now let the bombin questions start<br>1. I want to run a 4in duel exhaust no cat or muff good/bad? and will the egt rise/fall and how much? (a estamate is good)<br>2. What injectors do you recomend/why?<br>3. When I drive it in 4gear hard up a onramp for example the boost will run upto 20psi@2000rpm then I shift too 5th is this a good sign everything is working?<br>4. Will these mods get me close to say 200hp and what torque output?<br>5. Will I need to play in the fuel pump to get there?
Old Mar 9, 2003 | 01:36 AM
I ran out of room cont.<br>6. My truck will only rev up too 2500rpm is this the norm? <br>7. What clutch should I put in too harness this new power? <br> Thanks for your time and input Im new too diesels and dont want to be taken!
