Bump timing and HTT stage IV?
Old Sep 30, 2007 | 05:43 PM
ryan10's Avatar
Hey guys, how much of an improvement would it be if i bumped the timing 1/8 and put on a HTT stage IV?
here is what the truck currently has: pump mods: full power screw in about 1 and a half turns (too intimidated to take off the lock collar, afraid im gonna lose the stock setting when i do) starwheel 1 turn from bottomed and smoke screw in 2 turns. 14 cm wastegated housing, bully dog fuel pin, and bully dog injectors, and a built tranny.
1st, how much power am i pushing now? and how much of a gain would i feel if i were to do an HTT stage IV and bump the timing?
also, what next after that?
Old Sep 30, 2007 | 07:22 PM
The timing should wake it up pretty good, you have enough fuel that more timing will help a good bit.
Don't waste money on a Stage IV, it is not $85 better than a Stage III. Get a Stage III.
After that, turn the pump up until the EGT's scare you.
It's hard to say where you are power-wise. What kind of EGT are you seeing now?
Old Sep 30, 2007 | 08:17 PM
The Tank's Avatar
Call GDS they are in utah and have the same thing for 225$$. It is direct from holset 60mm wheel and housing, and sounds good
Old Oct 1, 2007 | 05:34 AM
ryan10's Avatar
OK, ill either look into the stage III or GDS. right now i can hit 1500. what is the best way to remove the lock collar on it, also, where is there a write up on how to bump the timing? is it something i can do myself?
thanks. How much of an upgrade will i see in boost with the turbo upgrade?
Old Oct 1, 2007 | 02:55 PM
MBolivar's Avatar
Ditto on calling Gillett Diesel Service. Talk to Steve and he'll hook you up. Great customer service.
Aloha,
Matt
Old Oct 1, 2007 | 04:07 PM
Look in the sticky for info on bumping the timing.
The easiest way to get the lock collar off is to take out the fuel screw so you can get at the thing. Then you can pry it off with a small screwdriver.
Old Oct 1, 2007 | 04:36 PM
ryan10's Avatar
Ok, thanks. how much is the gillette diesel upgrade kit? is the HTT better? how much of a boost increase will i see with an upgrade kit? also, i cant get to the bottom bolt on my pump. how easy is it to get to with an "S" wrench?
thanks.
Old Oct 1, 2007 | 04:42 PM
The HTT and Gillett upgrades are the same parts. You won't get more boost, you're wastegated.
The "S" wrench makes it look easy.
Old Oct 1, 2007 | 06:41 PM
ryan10's Avatar
forgot about that. thanks. thinking down the road, after the turbo upgrade and the timing bump, what next?
i was thinking maybe water/meth
Old Oct 2, 2007 | 05:32 AM
ryan10's Avatar
Ok, guys. i think im gonna do a water/meth system. should i leave the timing alone then? i heard i could blow a head gasket with w/m and timing advanced? also, its a play truck and i want to build the kit myself seeing it can be had for 250. Since its a play truck/ DD should i go with a hobbs switch or another kind?? whats the price difference between the two? also, how hard is this kit to install?
Old Oct 2, 2007 | 05:02 PM
With those injectors you have enough fuel to need more timing. I would bump it at least 1/8".
If you want it to feel like somebody kicked you in the butt, get a hobbs switch and save money. If you want it to feel smooth, go progressive.
Old Oct 2, 2007 | 05:28 PM
ryan10's Avatar
Ok, thanks. can you tell me if this kit will work? im 17, so money is tight and this is even cheaper than the DIY kit. will it work and will 150 PSI be enough? how hard is the kit to install?
here is the link to the kit:
http://www.coolingmist.com/pagedispl...e_key=standard
Old Oct 2, 2007 | 10:25 PM
D1EZEL's Avatar
You did not mention if you have a 3200 gov spring, best $16 I have ever spend. Bang for the buck its been the best improvement so far.
Old Oct 3, 2007 | 05:27 AM
ryan10's Avatar
NO, i dont have the 3200 spring installed yet. will the DIY dual stage water/meth be a better kit for 250, than this kit for 199? How much power will either of these kits add? should i do this or the compressor wheel kit first?
thanks
gman07
Oct 25, 2008 09:33 PM
Crossy's son
Oct 12, 2008 05:59 PM
royta
Nov 6, 2006 08:19 AM
LCH
Oct 26, 2006 05:10 AM
GR40RCapri
Jun 25, 2006 12:53 AM
