Bump The Timing?
Old Apr 9, 2008 | 08:41 PM
Rafter B's Avatar
Bump The Timing?
I read Wanna's sticky on timing bumping, but I still don't get it. Where is the reference point as I just bought truck and I don't know whats been done beforehand. Is it next to the bolt in the photo or somewhere else? Where is it @ factory setting? THANX AND SORRY FOR BEING SO STUPID. I JUST DON'T WANT TO MESS THE ENGINE UP!
Old Apr 9, 2008 | 09:31 PM
Carp's Avatar
No worries, you can push the pump right to the head without hurting the engine. There are two lines (reference marks) one on the pump by the nut you can see. It is best seen from the fender here is mine in the picture.The other is on the timing cover. Hope this helps.
Attached Thumbnails Bump The Timing?-timing-mark.jpg   Bump The Timing?-bump.jpg
Old Apr 10, 2008 | 06:21 AM
Rafter B's Avatar
Thanx, Carp, did you paint your engine? It looks green in the photos. Mine is grease. Thanx Again!
Old Apr 10, 2008 | 10:33 PM
Carp's Avatar
Yup, got sick of cummins recon beige and painted the engine "booger green". There is just no help for people like me
Old Apr 26, 2013 | 12:57 AM
crossy's Avatar
I'd like to see pics of other painted cummins engines- crossy
Old Apr 26, 2013 | 05:46 AM
Jim Lane's Avatar
Wow you have more Cummins than there are in all Southern California.
Is the Pinto a 2.3
There is a some guy around town that put a hollowed out 71 Pinto Hatchback on his 428 Cobra Jet, narrowed 31 spline 9" with tubs, looks complety stock, yea right.
Old Apr 26, 2013 | 07:22 AM
crossy's Avatar
the Gimpo is 2.0 german Sohc 'powered'?, the 1.6l was a pushrod engine and only avail with stick because it was so gutless. 73 was the last year for skinny bumpers and 74 was the first year for 2.3 engine.
Old Apr 26, 2013 | 09:23 AM
simplysmn's Avatar
yeah but the Pinto MAkes a great dirt track car they handle nice and boogie plus you can get some big HP from a 2.3 with just a 2 bbl carb .
Old Apr 26, 2013 | 09:38 AM
maybe368's Avatar
IIRC, they used to use pinto front ends in rail type dragsters. I have a friend that put a super charged engine in his pinto and it also looked completely stock except for the scoop in the hood for the blower. I don't remember how big but it was flat out fast...Mark
Old Apr 26, 2013 | 12:53 PM
ClassA4x4's Avatar
This is something not stated in many writeups: There is a swivel bracket bolt on the IP head bracket. I believe you need to loosen the bolt so you can rotate the IP.
Old Apr 26, 2013 | 03:11 PM
simplysmn's Avatar
Yes we use them in Ca. for dirt track mini stock race car's and there are several in the 160 + hp range they will flat out Boogie if you tune them right.
Old Apr 26, 2013 | 06:09 PM
93-12Smoke's Avatar
Yup, and on my truck if i want to go all the way to the head I'll have to enlarge the slot in the bracket. At a little more than an 1/8" and that is all it will go because of it.
Old Apr 26, 2013 | 10:51 PM
maybe368's Avatar
When I replaced my IP, they must have adjusted that bracket because the instructions said to push it all the way to the head. It nearly touches the head, it might even touch it...Mark
royta
Nov 6, 2006 08:19 AM
LCH
Oct 26, 2006 05:10 AM
GR40RCapri
Jun 25, 2006 12:53 AM
ouchman
Feb 15, 2006 04:47 PM
LanceD
Oct 25, 2005 11:16 AM
