building twins (i think) ideas advice etc...
Old Oct 16, 2006 | 11:30 PM
swampthang's Avatar
well i have decides with my wealth or usless knowledge i am going to build instead of buy a twin turbo set up for my truck lol i have benn all over looking at other peoples stuff and i think i have a good idea of how it all works so any and all info is a good thing the main thing i am looking for is type of turbos that i should use i have the stock turbo on my truck now
truck info
1993 dodge ctd w250 4x4 crew cab conversion p-pump conversion (215) custom fuel system based around a 150 F.A.S.S lucas pods nv4500 conversion dual range aux trans 3.54 gears long bed air ride custom 5in stacks/exhaust (not done due to twins) um i think that is all you need to know if not ask i will fill you in
Thanks
Jason
Old Oct 17, 2006 | 03:19 PM
The stock turbo with a 12 cm wastegated housing would work fine with an HT3B. Putting an HTT Stage III kit on there wouldn't hurt anything, but it's not a "must."
Old Oct 22, 2006 | 02:07 PM
johnny5.9's Avatar
twins
I was wondering, what are these HTT stage 3 and 4 kits that you guys are talking about? Also I too have pondered the idea of home made twins. What do you guys think about using an HX 35 or maybe an HY35 (to spool even faster) for the primary and using an HX40 for the secondary. Those turbos are readily available and not too expensive. Would the boost out of the 35 be too much for the intake of a 40? I would love to have twins but paying $4000 for them when I can fab everything but the turbos is just not justifiable. Twins would sound so sweeeeeet screaming out of my stack.
Old Oct 22, 2006 | 02:11 PM
Micaiahfied's Avatar
the 40 is way too small for a bottome turbo from what i have ready. unless you want 2 just so you can say you have 2, the bottom turbo should be significantly larger. also i believe the 9cm on the hy would be way too small. i am looking into a possible hx-35 and hx-60 combo right now.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
MrTwister
Competition / Pulls / OffRoad
18
Dec 30, 2007 04:04 PM
Stock 02
28
Sep 24, 2006 11:09 AM
