breakaway spring pin
I was just looking over my throttle linkage an di have alot of play on the idle arm. The breakaway spring is fine but the pin that is between the two ends is gouged up bad. It has some deep grooves in it allowing the arm to go where it wants to when i give it some throttle.
Brazing/silver solder and a file will fix it right up as well. I used a propane torch and some silver solder from the hardware store etc. IIRC that linkage bracket is close to $75.00.
