brake shudder?
Old Feb 7, 2006 | 09:33 PM
blue285k's Avatar
brake shudder?
Greeting, I'm assuming that I may have some warped rotors? I get a prety good shudder/vibration when comming to a stop on my 91 w250 regular cab? It seems to be getting worse. Any suggestions before I tear into it and tips on pulling the rotors?
thanks
Steve
Old Feb 13, 2006 | 05:21 PM
BC847's Avatar
1st Generation Admin
If you're gonna go through the trouble of pulling the rotors to be turned, go ahead and install new shoes/pads as well.
Make sure the tires are indeed round. I got slack once with keeping my tire pressures right, and had one tire wear stupid. It's warped! Egg shaped is more accurate. Pretty much ruined.
. . . . . . and on the front, it presents as though the rotor's warped.
I also once ran some 16.5 Eaton steel rims. In my application, they were crap. They kept fracturing at the weld of the rim itself. I expect the after welding heat treatment (relieving) was inadequate. I imagine the rim was flexing while in standard use, such amounting to cold working at the weld, resulting in it breaking.
. . . . .. Are your rims round?
Old Feb 13, 2006 | 05:42 PM
uncleroty's Avatar
Your problem could also be a sticky caliper, which is common on our trucks. If the shaking seems to continue after you let the breaks off, that will likely be the trouble. Otherwise, your diagnosis is most likely correct. I'd follow the advice around installing new pads as well.
Old Feb 13, 2006 | 05:50 PM
Geico266's Avatar
thanks
Steve
Welcome to DTR.
Please fill out your signature so we have an idea of what truck you have.
Old Feb 13, 2006 | 06:04 PM
edwinsmith's Avatar
I've had the most trouble with tire jockeys who overtighten and undertighten the lugnuts. They get some to tight and unbelievably some are just finger tight. This warps the rotors. They just did it to me again on my Blazer cause I didn't watch them and make sure they used a torque wrench.
Edwin
Old Feb 14, 2006 | 08:42 PM
blue285k's Avatar
Brake update
Had the Rotors turned (machine shop said they wern't that bad) installed new pads, and fresh grease for the wheel bearings and a little anti seize for caliper slides. what ever my problem was it is now gone! Thanks for all the input.
Steve
Rafter B
Apr 13, 2008 09:40 AM
mr T
Oct 10, 2006 10:51 PM
southtxfarmer74
Feb 19, 2006 12:16 PM
heavyhauler2
33
Dec 26, 2002 07:41 PM
bigbaddiesel
Nov 30, 2002 01:03 PM
