Brake question
Brake question
I finally got the crew on the road yesterday. But I have a problem with the brakes. The brakes stop good and the pedal feels good, it just doesn't return after you push it. I have to pull the brake pedal back up with my foot to release the brakes. Could this be the master cylinder or something else?
Thanks for any ideas.
AndyT
AndyT
Not sure about when bleeding the brakes, my wife was pushing the pedal. But she didn't mention anything.
The small line from the booster going over to the driver fender was attached to some kind of sensor, the fitting broke off of this when I tried to remove the line. I glued it back on, but I will check for a leak.
Thanks for the ideas.
Just went through it. I would say wanna is dead on. I did have to bleed the lines 3 or 4 times to get a good bleed. Now they are back to normal. Good Luck. New , in this day and age could still be faulty.
Well just got the booster changed out and it fixed it. The seal on the rod from the pedal to the booster was bad. I changed it out in the autozone parking lot today during lunch. It is much better now. Thanks for all the ideas and help.
AndyT
AndyT
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
ddestruel
Apr 6, 2005 11:26 AM
wvcowhauler
13
Apr 3, 2005 11:39 PM
