Brake problems question
Old Mar 15, 2013 | 02:43 PM
Mule Man Willie's Avatar
Unhappy Brake problems question
I had a blown brake line (the long front-to-rear one between the frame and fuel tank)
I replaced it, and blew out two more. Replaced them.
I just use my truck for farm use and I think this line has been bad for a while.
I bled my brakes until I got all fluid. But now I get no pedal at all until I pump them, then good pedal and good brakes.
I looked at what I assume is the anti-lock brake thingy beside the spare tire and saw it also has a bleeder, which I twisted off.
Just wondering if this is my problem, it needs bled too? And if so, can I just bypass this thing instead of trying to get the bleeder out or buying a new one?
Thanks in advance.
Old Mar 15, 2013 | 03:10 PM
BILTIT's Avatar
You still have air in the system so yup that anti lock thingy is probably part of the issue. You can bypass it.
Old Mar 15, 2013 | 03:23 PM
Funny thing is, I had good pedal with a blown rear line and empty MC chamber, now I don't.
I looked through the "Brakes" sticky and I assume that's the dump valve. Both lines are 3/16 but two different size fitting bolts. Any idea if there's a union made that will join these two?
dieselluvr
Dec 29, 2013 11:02 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
coalburner400
Aug 1, 2006 06:37 PM
95 Dodge
Jul 2, 2006 03:28 PM
