brake lights stuck on
Old 06-13-2018, 07:10 PM
Silver R/T's Avatar
My brothers 92 W250 brake lights are stuck on. Whats might be cause? Im thinking brake light switch or??? How would I check brake light switch to see if its bad
Thanks
Silver R/T is offline
Old 06-13-2018, 07:15 PM
Thanks
I had a trailer brake box go bad and the lights would not go out
cabtruck is offline
Old 06-13-2018, 08:25 PM
The brake light switch under the dash can move back if hit or the pedal moved up for some reason. Have him pull up on the pedal and see if the brake lights go out, if not reach up under the dash following the brake arm until he feels the brake light switch. Once the switch is found should be able to feel it sitting against the arm, if not then it is out of adjustment. Can also push on the switch to see if the lights go out.
Mine was worn out and would only hold adjustment for a couple days, until I got it into adjustment then used a couple small zip ties to hold it in place...been great for over a year now.
thrashingcows is offline
The Following User Says Thank You to thrashingcows For This Useful Post:
mknittle (06-14-2018)
Old 06-13-2018, 09:09 PM
Silver R/T's Avatar
yeah it was brake light switch
The Following 2 Users Say Thank You to Silver R/T For This Useful Post:
mknittle (06-14-2018), thrashingcows (06-14-2018)
96_12V
0
10-14-2011 10:42 PM
polaris800sp
11-13-2008 05:35 PM
Baja
01-29-2008 08:17 PM
RoostrRiz
01-25-2005 03:17 PM
Quick Reply: brake lights stuck on
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
