brake issues, sorry!
Old Jan 21, 2013 | 08:56 PM
bryson711's Avatar
i know this is a common thread. i have been searching for the last 2 hours trying to figure out what is going on. when i push the brake pedal in i get nothing. it goes straight too the floor so i went through process of elimination. i have adjusted the rears, replaced the booster and the master and still have the same problem. it does not want to build pressure. it will if the truck is off and i pump the brakes. but as soon as i start it it goes straight back to the floor. i have bled the crap out of the system. also the abs has been unplugged and bypassed in the rear. could it be a vacccum isuuse? the cruise and heater controls all still work so i am kinda stumped?
Old Jan 22, 2013 | 12:57 PM
Chrisreyn's Avatar
Vacuum assists in braking, loss of vacuum should make the pedal stiffer.. it sounds like the symptoms of an air bubble in the system or a loss of hydraulic pressure..
Old Jan 22, 2013 | 01:20 PM
Lunds Ram's Avatar
Id check the rubber lines, you might have a leak somewhere
Old Jan 22, 2013 | 03:26 PM
bryson711's Avatar
I will try to check some more stuff. I'm gonna buy 2 plugs for the master and undo the lines and plug them and try to eliminate the mater and brake booster
Sent from my DROID4 using Tapatalk 2
Old Jan 22, 2013 | 05:19 PM
j_martin's Avatar
You are either losing fluid, ballooning a hose, or have an air bubble in it. I'm assuming the master cylinder you've installed is good. (DOA's do occur)
The rear brakes have to be bled by the book, or they'll trap air.
Old Jan 22, 2013 | 05:51 PM
MARF75's Avatar
On occasion my brake pedal will go right to the floor with no takes,but it's usually after a back and forth session with the steering wheel or a full lock turn.
Totallyrad
Jan 7, 2008 05:31 PM
nevrenufhp
14
Nov 27, 2002 09:55 PM
dealseeker
43
Nov 18, 2002 11:47 PM
admin
Oct 13, 2002 09:09 PM
Commatoze
Oct 11, 2002 11:03 AM
