Bottom door hinge fix
Hey guys just curious has anyone ever developed a fix for the bottom of the door hinges that seem to inevitably overtime crack and start to pull the bracket from the inside out? I have heard of people welding metal plates on each side to reinforce it but its starting to become more of an effort to get the drivers side door to close fully
Page 37 in my build thread shows you what I had to do to fix my drivers door, and the reinforcement plate I made.
https://www.dieseltruckresource.com/...305923/page37/
If you look at it, you'll see a relatively small threaded backer plate held in by 2 or 3 crimped tabs. Pry it out and grind off the tabs, and there's an irregular shaped flat spot about twice as big. Fashion a plate out of 3/16" or 1/4" plate to fit that space, drill and tap the hole pattern, and put it back together. The force of assembly will pull the metal back into place.
Some folks pull it in and weld it before they replace the backer, but I didn't. Seems to be holding fine.
The lower hinge stop is the only stop on these things. Forces there could be measured in tons, which is why they tear out.
Yes like thrashingcows posted on his write up he did the welding on the outside edges, but even with that plate with the tabs removed and then the metal sheets put in place did either of you guys have to replace the hinge itself or use a better type? I don't think mine is that bad but still couldn't find anywhere that offered the hinge and would hate to have it come down to the dreaded s t e a l e r-ship
I don't have a readily available alternative in mind yet. But I think the bronze bushings in the kits don't have enough surface area to last long.
I need to dig out my extra set and do some thinking.
Wish I still had access to a lathe.
Mic em. I bet there's some commodity bushings out there, like fleabay or McMasters. How does the pin wear?
Pin doesn't seem to wear, just the cheapy bronze bushing. And Yes Mark they were the ones from the "Help" rack at the parts store.
Good idea Mr. Martin...finding them in a harder material would definitely help.
Theres a guy on ebay aka (mystery man) , who also used to be on here, that makes a fully enclosed hinge with grease fittings an all. all high quality stuff never wear out. he also sells the best rear main seals for these engs (no leaks), yes better than original.
