Borgeson Question
Borgeson Question
I notice Borgeson has two seperate steering shafts listed for 1st.Gen. trucks.
The better looking shaft states that "must have removable rag-joint".
How do I tell if a truck has this "removable" joint??
Can the 91.5 truck use this better shaft??
Thanks.
The way to tell is to look at the steering shaft where it comes out of the fire wall. The metal part of the rag joint on that side will either be welded on or have a spline and a pin, kind of like the coupler to steering gear connection. I have a late 91, mine was pinned. I used the double U-joint set up, but had to shorten the inside section of the shaft a bit to make it fit.
I think I used the cheaper one on mine. Works great. PITA getting the roll pin out of the stock coupler, though. Be careful to block that shaft with a stout piece of wood jammed in behind before you start wailin' on it.
