borgeson install - now slight problem
Old May 10, 2008 | 08:16 PM
wminmi's Avatar
did my borgeson install today and WOW!! definately worth it!!
Problem now is, seeing how I didn't have a grinder or file handy, I drilled a "pilot hole" for the set screw and of course, as luck would have it, went to darn deep and now leak fluid
Anybody have any tips on fixing this?
Don't want to have to change the gear box if i don't hafta.....
Old May 10, 2008 | 08:22 PM
mullishacrew's Avatar
hmm if you be steady and carefull, you can weld the hole up, and the take a grinder and gently re grind the grooves.
Old May 10, 2008 | 08:40 PM
wminmi's Avatar
thought about welding it shut, or at least half shut to where the hole is filled, but don't have my welder handy. may find a local welder though and give it a shot. t
thanx
Old May 10, 2008 | 08:44 PM
BearKiller's Avatar
That's a very simple fix.
If you don't have any, get yourself a stick, or a dozen, of two-part plumber's epoxy putty.
ACE hardware, TruValue, or any decent hardware store will have it.
WalMart, Advance, and all the other chain-gangs also have it; but, they have it labeled something line Instant Steel, or somesuch.
What it amounts to is a cigar-sized stick of two-colored putty.
Cut yourself off a nickel-sized slice, roll it in your hand and work it up like Play-Doh.
When you feel it starting to get warm, and the color is now consistent, dab it in the hole, pushing it in there good.
Of course, you already wiped off most of the oil/dirt with some kind of thinner.
Coat the inside splines of the coupler with anti-sieze and slide it back on there, lock down the screw, and no more leak.
Don't ask me how I know so much about fixing this leak.
Old May 10, 2008 | 08:47 PM
wminmi's Avatar
well, it is good to know i'm not the only guy this has happened to
Thanx, will give this a shot as it sounds easier than digging up a good local welder on a sunday
mitchellalso
Sep 6, 2010 02:45 PM
sallyman1
Jan 27, 2009 10:33 AM
GIT-R-DONE
Feb 11, 2007 11:15 AM
Common
Sep 19, 2006 05:27 PM
bigredbrick
Jun 18, 2003 10:33 PM
