Boost Gauge problem???
I installed my boost gauge and pressure tested the whole thing from the manifold connection to the gauge and everything works great. However, when I hook it up to the spot in the manifold, the gauge doesn't move. I reved it up and still nothing. Do I need to be driving for it to work or should I be reading something at idle?
Originally Posted by 89dieselkong
(Post 1175186)
I apologize for being ignorant on this[dummy] but does that mean that at idle the gauge isn't going to move?
thats right
Also over tightening the compression fitting on the tubing will/may cut you off.
(Post 1175196)
Thanks Wanna...reasurance helps a ton for the beginner..
Originally Posted by flashgordon
(Post 1175193)
there has to be a load on the eng to cause enough heat on the ex turbine to Create boost.
I took her out last night in the city (at work) real quick. I didn't get to open her up, but I got the boost gauge to move (phew) Now I am anxious to start tweaking her a little more!:eek:
(Post 1176297)
What kind of boost are you getting at full boogie, in high gear. |
I haven't had the chance to run her wide open yet (city streets), but she hit 18 when I let off. I am leaving work in the morning and am going to play a little on the way home to get more accurate readings...will post results after
Your 89's setup is similar to my early 91. You will probably be hitting around 25 to 30 psi on highway climbs with it pegged. The non-intercooled trucks develop more boost because of the plumbing the air does not have to run through. This is not that much of an advantage because of the higher intake air temperature of the non-ic'd engine. I love the winter only for the power boost we get.
Originally Posted by Bill Tomlinson
(Post 1176448)
I'll secant that one![laugh] |
I can boost over 10 psi in park.
Originally Posted by drolex
(Post 1299400)
